Home > Technical (L405) > Lower tail gate does not work!?
JLS
Norway
Hi!
My lower tailgate does not work. It does unlatch, but the tailgate does not move. I need to do it manually. The same when closing. I need to lift it up, but the soft close sucks it in and latch it.
I have the GapIID-tool, and here I get the fault message: C2006-13 - left actuator - general elctrical failiure - circuit open.
Which unit is broken? Does anyone any experience, and picture of the actuator that I need to check/replace?
Thx
Jan L-S 2016 L405 SDV8
1962 Series 2 a petrol
1965 MB 230 SL
Post #726265 16th Oct 2025 3:39pm
Hopefully there's something in here to help -
https://www.fullfatrr.com/gallery/albums/u...osures.pdf
I've replaced my upper actuators, but not the lower ones.
Post #726268 16th Oct 2025 4:47pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Cheers Alistair , my lower has ceased to function too . 2019 SV AB Dynamic Scafel Grey
Post #726280 16th Oct 2025 9:02pm
Mine needed a new anti-trap sensor & I also had to solder a break in the tailgate wiring loom Shocked
https://www.fullfatrr.com/forum/topic47843.html
Post #726304 17th Oct 2025 8:34am
This is also worth checking - https://www.fullfatrr.com/forum/topic66566.html
Post #726305 17th Oct 2025 8:42am
JLS
Norway
Thx, Alistair. This was usefull, but according to the drawings I can find the LEFT actuator on the lower gate. It has just one actuator as I see. Could it be the self closing actuator C2006-13 is refering to?
JLS 2016 L405 SDV8
1965 MB 230 SL
Post #726325 17th Oct 2025 12:29pm
JLS
Norway
…can´t find the actuator… 2016 L405 SDV8
1965 MB 230 SL
Post #726332 17th Oct 2025 2:09pm
Gremlin500
Item number (7) see WM above for disassembly instructions
 V6 Vogue - “Less is More” - less to go wrong!
Post #726337 17th Oct 2025 3:24pm
Agree, AFAIK the lower has a single actuator.
Have you tried clearing the fault & trying again - just to confirm that it is caused by opening & closing the lower part only & isn't referring to a historic fault on the upper tailgate ?
I guess it could just be down to using common software with other vehicles that have left & right actuators.....
Post #726340 17th Oct 2025 4:53pm
