![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 414 ![]() ![]() ![]() |
Thanks gents. Regen status is the important one really and I can’t get it on the dashboard yet. 🤷♂️ |
How can the dpf remaining volume be nil? I had the amber warning last night and took the car down the m/way to clear it….
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1874 ![]() ![]() ![]() |
If its 167m since the last regen, presumably that wasn’t last night?
Yeah that’s correct 167 km not miles. I’ve been out in it today. The regen must have happened as the amber light went out last night. 🤷♂️ |
It’s well worth spending some time getting your phone Dashboard set up correctly so you can see what’s going on at a glance and in the correct units. It can seem a little bit daunting at first, but just play around with the Dasboard settings/Font sizes & Colours/Trigger Values until you’re happy.
Once you have it sorted on the phone display, you can even use CarPlay to display on the car screen either wired or wireless:
That’s the best display I’ve seen, very clear 👍
The sensor is on this list but not available on the dashboard? |
Hi Richie,
Top man I think that’s worked 👍
I spoke too soon 😩
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3390 ![]() ![]() ![]() |
On the GAP tool it doesn’t show a value for remaining volume or for that matter quite a lot of values even though they are selectable as data displays. All you really need for monitoring is the estimated ash in grams and number of demanded regenerations. 2012 TDV8 Vogue (L322) |
Thanks and fair enough. But the important one is when the Regen is active/running and I can’t get it 🤷♂️
Most use the EGT and EGR values to indicate a regen in progress. 2012 TDV8 Vogue (L322) |
