![]() | Home > Technical (L322) > 2010 3.6 TDV8, dreaded oil cooler water leak. |
| Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 238
I assume you mean the assembly deep in the "V" of the engine with the oil filter housing, fuel cooler and crank breather. Where is the coolant leaking from, front of the engine, middle or at the back, several options for leaking. |
| Healeyv8 Member Since: 25 Dec 2023 Location: Research Victoria Posts: 5
Thanks for your reply, really hard to determine, I have been able to smell the coolant leak for awhile, no stains on the driveway yet, had a mate pressure test it, small leak seems to be at the firewall side of the oil filter. I am after the better after market parts, the OMParts are way over the top here in Australia. I guess I will have to start pulling stuff off and find the leak. It’s definitely not coming from the thermostat housing. Using about one liter a week. The om rubber gasket for the oil cooler , oil filter is around $180 ASD. Thanks again regards Lance. |
| Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 71
Yes people have just changed the gaskets and that works fine. I think that because it’s not much more here to get a whole unit from an ok brand like Nissens, they take that option instead.
Thanks for that, I will try and find if someone in Australia sells that brand, all the best Lance. |
Not sure on the Sport but on the FF if you remove the cabin air filter housing (2 bolts) you can, whilst lying on the engine, get a better view of the oil filter/ fuel cooling block and determine whether there is coolant visible, on mine the seal of the fuel cooler went, there is no seal available for that so I left the seals and sealed it with JB Weld Ultimate Black RTV, seems to have done the job. As Steveg mentions, when you are that far into the engine you might as well change the seal, part no:LR002340, it does involve taking the EGR's off, the coolant block on the front of the engine (1 bolt is hidden onderneath it)and you will have to do an oil change, coolant everywhere. Having flexible reach hose clamp pliers will make your life a lot easier as there are a whole lot of hoases that need to come out.
Thanks Will great advice, do love this Ford derivative engine twin turbo 3.6 280 hp, I have chipped it , blocked the egr valves and now it’s 350 hp. I will pull the cabin filter out tomorrow, thanks again, all the best Lance. |
Hi Lance,
Thanks Will, that’s a great link, I have been searching for a manual ( obviously for free) 😀 , this link was what I have been looking for. I remember way back in my old two door, it had a cracked, used cemieweld for about six years to stop the leak. I am not game to put it in this engine. Thanks again Will. |
| mpwdhc Member Since: 22 Oct 2025 Location: Adelaide Posts: 4
Hi from Australia. A question about the oil cooler - does coolant pass through it into the engine, or just from one top outlet to the other top outlets? Have a TDV8 with oil in the coolant. Cooler was replaced some months ago. The engine is too happy to really consider HG failure. I’m trying to decide whether to do the whole assembly or just the cooler itself. |
Morning,
Ok, thank you. I presumed based on pics the coolant just passed in and out through the outlets on top, and only oil flow through the lower outlets.
I also replaced the "O" rings on the oil filter housing and breather, can't remember the sizes but I used Viton or some other high quality "O" rings and it all sealed beautifully.
Thank you, so are the two small fittings on the top of the cooler oil pipes to turbo or similar?
The 2 fittings on top are fuel lines, one to the back of the engine, the other one to the fuel filter area.
| All times are GMT |
