![]() | Home > Technical (L405) > 2014 SDV8 help needed |
| 4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 460
Certainly seems like there are quite a few modules not communicating, can you talk to the KVM unit?
| RRRyan Member Since: 22 Jan 2024 Location: Wigan Posts: 5
Yes I can communicate with the kvm I sorted the steering column lock by grounding it to the body from the ground pin on the plug for the esl
What is the CKP fault you are getting?
Here is pictures of the fault code
But these are the ones I’m mainly concerned about
If anyone could help I would really appreciate it I’m pulling my hair out atm |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1901
I suppose you already checked the main wheelarch earths?
Has the engine run since the ckp was changed?
| nike_bytom Member Since: 29 Mar 2025 Location: Thrapston Posts: 28
Hi,
| All times are GMT |
