![]() | Home > Technical (L405) > Stupid Question.... |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
On my car the lights are switched on and off by touching the lens. Only Range Rovers since 1988 |
| sullivj Member Since: 19 Jun 2025 Location: Gatwick Posts: 62
Thanks CS. Maybe I have two blown bulbs as that doesn't work for me... |
| 4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 457
They are LED's so unlikley to have them fail, check if the vanity mirrors light up when you slide the mirror flap across, if not there's an unfused protected output suplying voltage to this circuit that includes map lights, vanity mirrors and some ambient lighting. Common fault is a trapped cable to the sun visor(s) which the BCM detects and shuts down the voltage until the fault is rectified - ask me how I know!!
Thanks 4RRS. I will check the vanity mirrors. |
I think you’re onto something 4RRS.
I think the auto dimming function of the rear view mirror is also on the same circuit and they would have removed that, I'll check the diagram when I get a moment.
Thank you again 4RRS.
So, I had a visit for Clive at CDS 4x4 who tried to reset the protected circuit on the BCM, but it did not have any fault codes showing on his diagnostic. He suggested I checked the fuses.
| All times are GMT |
