![]() | Home > Technical (L322) > Heater fan not starting |
| Bardley Member Since: 01 Jan 2025 Location: Hertfordshire Posts: 58
This is possible..the Heater blower motor resistor can play up.
| Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 85
Thank you! I have ordered a Replacement for the FSR.
A update regarding FSR… In june I replaced the FSR with a part bought from a general parts Company in Norway. Two months later the fan stopped working again. I read on this forum that the cheap EBay parts dont last, so I ordered a original Land Rover part from Maltings 4x4. It came in a proper Land Rover box so I guess it is the real thing. But when I removed the «cheap» one it turns out that they both are similar BMW parts. So I just paid 5x more for the same part! I just hope the expensive one will last longer…
It happened again!
| madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 116
Could be the blower motor seized up. A weak spot on these cars. Possible to diy to save a lot of ££££ |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032
yep, blower motor could need replacing, many of us have had to bite the bullet and do it before winter sets in |
Thank you! Will a partially seized fan motor destroy the FSR? 2006 Supercharged |
yes, the blower motor fan assembly has two circular rotating fins ( blades ) , they keep sticking after a while, poor design by JLR, and the FSR overloads and fails time after time - it took me and a friend all day to remove the dashboard and install a new one, been perfect ever since !
Thank you for the information about the sticky heater motor. Today we fitted a new FSR, and the fan did not work still. I removes the FSR and moved the fan blandes with a screwdriver. I were able to move the fan, but not easy. I guess this is a sign that the fan needs to be changed, so I will order a new one. I have unplugged the FSR to keep it from overheating and dying.
| All times are GMT |
