![]() | Home > Technical (L322) > Td6 gearbox oil change |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 860 ![]() ![]() ![]() |
Hello, did anyone change the oil for the Td6 GM5L40 gearbox? Is there a filter in too? The manual only explains how to change the oil but doesn’t mention a filter... |
I think I found the procedure here: http://www.bimmerfest.com/forums/showthread.php?t=239968 |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
It's been covered by a forum member in the TechniCal section
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
The post in the tech section is for the 4.4 BMW petrol - the diesel's gearbox is different |
The GM5L40 is also known as the BMW A5S360R, as long as that write-up on the BMW forum is for the 360 or 390 (the slightly upgraded version - aka the GM5L50) then it should be a good starting point.
Sorry chaps for the misleading info from me. (Slap back of hand naughty boy) Discovery 4 HSE
OK< I know this post also talks about the 4.4 but it still makes interesting reading:
OK, two problems, The filter is over 200EUR, and there is no Texaco ETL 7045E oil in my country! Is there an equivalent from a different brand?
OK, so if we're talking about a different gearbox on the BMW site, can anyone give me the code for the GM 5L40 filter? I presumed it was the BMW THE 00030 part, is this correct? There is no mention of the filter in Microcat... |
THE00030 is a Land Rover part number (or would be, but it's missing a number - should be 6 numbers).
Also, I would check the LR spec for the gearbox oil, they may have an alternative requirement to BMW and so use a different fluid... |
Thank you for the replies!
OK, I found the filter/gasket kit for 40EUR and the oil at BMW (Texaco ETL 7045E, BMW p/n 83 22 0 026 922) for 11EUR/liter. Will try the procedure in a day or two and I will post pictures and results. I spoke to the BMW engine/gearbox specialist and his opinion is (although he’s against touching a gearbox if there is no sign of malfunction) that the GM gearboxes have filters that clog easier. Therefore a filter and oil change are recommended after 60-80000km... |
