Home > Technical (L322) > Heater Blower not working ?
Johnte
Heater blower isn't working, although lights on dial are (day after fitting a new battery - may be coincidence Confused ) I did a search and thought 'FSR job done...' So off to Stratstone this morning and collected one, spent 1hr+ and skinned knuckles fitting, and still not working Big Cry - any ideas please - wrong time of year not to have a blower...
Post #97241 12th Dec 2011 2:38pm
FSR:
http://bimma.me.uk/2009/03/13/replacing-th...kiii-2002/ .
Post #97242 12th Dec 2011 3:00pm
re-check the connections and fuses john... ... - .- -.
Post #97244 12th Dec 2011 3:03pm
Johnte
Thanks Stan, I've checked fuse 34 - according to the manual, this should be the blower Confused Also had FSR removed and connected 3 times now and still no joy Big Cry
Post #97247 12th Dec 2011 3:27pm
you could try the battery dis-connect / re-connect...[by the book mind ! ] ... - .- -.
Post #97248 12th Dec 2011 3:28pm
try taking out the pollen filter cover and have a look at the blow fan blades..
have a look at the 14th post down.
http://www.fullfatrr.com/forum/topic7098.html?highlight=fsr ... - .- -.
Post #97251 12th Dec 2011 3:36pm
Can I also suggest that you check the following fuses, although not directly blower protecting they serve various Hevac ecu functions and may be related.
Fuse 64 50A
12 10A
34 7.5A
61 50A
53 30A
Also have you checked that the +ve feed connection for the fuseboard at the pyrotechnic device at the battery terminals is tight?
Post #97253 12th Dec 2011 3:47pm
Johnte
^^^^^ Done - Unfortunately all fuses OK.. Sad
Post #97262 12th Dec 2011 4:09pm
The only thing I can think of is that a fault has logged on the Hevac ecu at battery changeover for some reason and now needs cleared.
I doubt your blower motor has gone.
Post #97270 12th Dec 2011 4:18pm
Johnte
Removed the front housing this morning, blades seem to turn OK Confused Think I'll order another FSR before I strip down any further. I suppose it's not unheard of for a new one to be faulty Shocked
Post #97476 13th Dec 2011 1:19pm
i'm still leaning to bad connections/wiring john but it could be a faulty fsr. ... - .- -.
Post #97493 13th Dec 2011 2:33pm
