![]() | Home > Technical (L322) > Heater Blower not working ? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
FSR:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
re-check the connections and fuses john... ... - .- -.
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 744 ![]() ![]() |
Thanks Stan, I've checked fuse 34 - according to the manual, this should be the blower |
you could try the battery dis-connect / re-connect...[by the book mind ! ] ... - .- -.
try taking out the pollen filter cover and have a look at the blow fan blades..
Can I also suggest that you check the following fuses, although not directly blower protecting they serve various Hevac ecu functions and may be related.
^^^^^ Done - Unfortunately all fuses OK.. |
The only thing I can think of is that a fault has logged on the Hevac ecu at battery changeover for some reason and now needs cleared.
Removed the front housing this morning, blades seem to turn OK |
i'm still leaning to bad connections/wiring john but it could be a faulty fsr. ... - .- -.
