![]() | Home > Technical (L322) > l322 rain sensor/intermiant |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35752 ![]() ![]() |
in that sequence it does set the sensitivity of the wipers..
You can have the "Auto Wipers" disabled by the dealer or by an indy with the right computer. You can then set the variable delay to be 5, 10 or 15 seconds.
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
One possibility is in the screen-mounted sensor; do you also have trouble with the automatic lights? The same sensor doubles for both wipers and lights on.
2004 wouldn't have had auto lights - same principle applies though to check the wiring. Especially if it's ever had a replacement screen. |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
ok will look at these points and post my findings
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1761 ![]() ![]() ![]() |
If it's a 2004 without auto lights then chances are it does not have auto wipers either. Mine didn't until I bought the sensors and new LCM (for the lights)
Good shot from comports of a mirror without the sensor. If yours looks like this then there's no sensor:
Comports has the only Vogue I know of with no rain sensor.
Suppose it may have had the screen AND mirror etc replaced at some point in the past. The wiring would be there then, easy enough to check I guess.
Not any more Dan - thanks to you guys help..!! |
agreed... but it would go against all printed LR advertising literature as well as the workshop manuals. I actually wonder whether comports original owner asked for the car to not have the feature? ![]() |
mine has the rain sensor you can see the lens against the screen will unclip and see if its dislodged .
I'd be surprised if it is a Vogue SE being a 2004... the Vogue SE was introduced on the 55 plate. With the occasional 05 sneaking through. ![]() |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
My mate has an 05 Vogue WITH rain sensor but WITHOUT auto lights. Odd I know... |
