Home > Technical (L322) > Range Rover Key Transponder
andrew.aa
Italy 2004 Range Rover Westminster 4.4 V8 Java Black
if you lost all keys with PCF7936AS can be generate through two tools, one for reading EWS ECU and one for writing b,lank transponder
if you want clone ThIS chip,you need just one tools , that can write 7936
I programmed new chip by EWS EDITOR, connecting ews and readin eeprom , than generate and add new key.
the work process of dealer that you are talking about , is equivalent just to adding a key onto immo ews.
Post #131525 17th Jul 2012 12:16am
daveo
do you have some links to where and what you bought. V8 facelift Range Rover Autobiography 22" wheels.
Post #131534 17th Jul 2012 7:52am
daveo
ok, got a big massive eye glass and my chip is a PCF7903AS .. i just want to make a second key. V8 facelift Range Rover Autobiography 22" wheels.
Post #131863 18th Jul 2012 5:56pm
Here ?: http://www.ecutool.com/EWS-Editor-V320_6202.html .
Post #131884 18th Jul 2012 9:40pm
andrew.aa
I'm sorry for delay, due so much work this week, but Joe put the correct link for EWS EDITOR
I bought from other seller, a little more expensive, but I believe is the same tool.
Daveo, if you want generate new transponder, like PCF7930AS , I can send you ews editor, if you want, send me pm.without problem.
Post #132176 20th Jul 2012 12:29pm
daveo
hi Andrew, what other tool did you use to write the chip or did the ews editor do the whole job... i have done a bit of looking on the net and it seems to be quite straight forward, did you come across any problems
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #132257 20th Jul 2012 9:21pm
andrew.aa
I bought ews editor because I lost all keys so I needed to read from ews than generate transponder.
but if you have one key, is possible to clone transponder, directly from ews or from others similar tools.8other tool can't read ews and can't generate new key from zero)
to Work with ews editor is very easy, don't worry, you need just 5 min.
the ews editor can read ews, write ews, and write blank chip, you do not need other
Post #132910 25th Jul 2012 4:41pm
