Home > Technical (L322) > Touchscreen frozen
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
Touchscreen frozen
My friend has a 4.4 v8 Range Rover L322 and the touchscreen has locked up with an orange flashing light, it occured once the battery went flat and was jump started. Tried pulling out the fuses, done a hard reset, took battery off and left half hour. Still same problem. Any suggestions? My friend is Big Cry gone fishin'
Post #136689 18th Aug 2012 5:40pm
Dont jump start a FFRR! Sorry, but its a fact... Probably an ECU gone pop!
Craig Thumbs Up
Post #136694 18th Aug 2012 5:57pm
andyboy
Thanks Craig, just had a look in the back and found some signs of condensation in the plug on the nokia phone unit. We are going to check the rest of it out. Will let you know. gone fishin'
Post #136696 18th Aug 2012 6:17pm
BrianC
Sounds like a faulty Bluetooth unit to me
Post #136702 18th Aug 2012 7:44pm
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Cam-Tech-Craig, why do you say don't jump start a FFRR? The reason I ask is because instructions on how to are given in my handbook and your contradiction confuses me as to what I should do if the need arises.
Post #136705 18th Aug 2012 8:28pm
Simply charge the battery, yes if your stuck in the middle of nowhere and have no choice, then it is what it is! But if you have an option, always charge the battery because jump starting is like removing the battery from your laptop when its switched on... A no no... You may get away with it 8 out of 10 times...
We've had lots in with fried ECU's after jump starting which costs owners a fortune...
IMHO............
Craig Thumbs Up
Post #136716 18th Aug 2012 10:28pm
Brian GOG
United Kingdom 2002 Range Rover HSE Td6 Epsom Green
Hopefully its not an ECU but I would reitarate Cam - Tech Craig and try not to jump start this vehicles wherever possible. In my experience with the locked screen its usually been down to a break in the MOST fibre optic circuit. The bluetooth module is normally the first point of car. If you don't use the bluetooth or just want to elimate it you can buy MOST prisims from LR dealers for about a tenner. It just plugs into the fibre optic circuit in place of the module. If you have removed the faulty part the screen and other controls should return to normal operation.
If the dealer can't find the part number, let my know and I will get it for you.
Thanks
Brian
Green Oval Garage
Post #136832 19th Aug 2012 10:51pm
Pet monkey
Wales 2005 Range Rover Vogue SE 4.4 V8 Buckingham Blue
touchscreen locked up
Hi, thanks for your reply, I am having difficulty finding the MOST prism that you mention, I have contacted a few suppliers and no one knows anything about it. Big Cry Any part number or advice where I can buy one would be a great help.
Thanks. Mike. (new member)
Post #138619 30th Aug 2012 9:30pm
andyboy
Hi pet monkey I found a bloke near by that might be able to help you,
Cheers from andyboy gone fishin'
Post #138622 30th Aug 2012 9:38pm
Brian GOG
Part no you need is LR019014
Thanks
Brian
Post #138657 30th Aug 2012 10:56pm
andyboy
Thanks Brian Thumbs Up gone fishin'
Post #138834 31st Aug 2012 7:55pm
