Home > Maintenance & Mods (L322) > leaking FF! |
Sunroof drain blocked in the A pillar?
27th Aug 2012 2:28pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7632 |
Sunroof drains...........? 2011 Range Rover Vogue SE 4.4 TDV8
27th Aug 2012 2:29pm |
Ah, Craig must have beat me by a few seconds...........
27th Aug 2012 2:30pm |
27th Aug 2012 2:32pm |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 |
Thanks guys, its still raining so won't need to add any water,..
27th Aug 2012 2:33pm |
The school of thought if you look on the net, appears to be to use compressed air up the tube in reverse.
27th Aug 2012 3:04pm |
spot on, thanks guys! Definitely the s/r drain on the driver side.
27th Aug 2012 3:31pm |
Not sure on the L322, but I'd imagine you'd have to take the inner wheel arch liner out....
27th Aug 2012 3:42pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
Bicycle brake cables are usually good for this. You can often get a 5m piece from your local bike shop for around £1. If the end frays a little they are even more effective, but get harder to work with.
27th Aug 2012 3:51pm |
Ah, the pleasures and smugness of owning an HSE..... .
27th Aug 2012 4:24pm |
27th Aug 2012 4:30pm |
