Home > Technical (L322) > Restricted Performance Warning
duka
2010 Range Rover Autobiography 4.4 V8 Alaska White
Other than the handbook stating 'contact the dealer' only clues wo why this would have just happened on TDV8 4.4 - my wifes car & she's stuck back of nowhere hence the Q
any guidance greatly appreciated
edit car won't go above 10-15mph
Post #143154 26th Sep 2012 2:52pm
Could just be the DPF needs cleaning. If she turns it off waits a few minutes and then if all OK try to drive it in high revs for a while to clean it out...
Gary
Post #143155 26th Sep 2012 3:00pm
On the other hand it could be a turbo problem but lets hope not:
http://www.fullfatrr.com/forum/post59815.html
Post #143156 26th Sep 2012 3:04pm
2010 car so it will under warranty but its the hassle of getting it done...hope its not a big problem DUKA.. ... - .- -.
Post #143157 26th Sep 2012 3:05pm
Yes more important that your wife's OK....
Post #143158 26th Sep 2012 3:06pm
duka
Gary
We've been through the DPF 'clean' regime a few times with too town driving. Wife has managed to limp car home with lots of irrate drivers (even with hazards on) as she could get it above 12-15mph - now awaiting a laptop to find the error codes....
will update for all when known, hopefully a turbo pipe rather than an actuator or turbo...!!
Post #143159 26th Sep 2012 3:20pm
ebajema
Pretty infuriating to have these sort of issues with such a young car Sad Hope it is something small and easy to resolve. MY 2010 5.0 SC Galway green and sand interior!!
Post #143164 26th Sep 2012 3:46pm
duka
AA there now (via LR Recovery) plugged in laptop and they can't find any errors.
Not sure if AA have full access to all error codes??
Post #143181 26th Sep 2012 5:20pm
i doubt if they have every manufacturers codes tbh, probably only the general ones which , in your case wont show any errors.. ... - .- -.
Post #143188 26th Sep 2012 5:53pm
duka
Correct stan, car collected today on a trailer en route to dealer, black smoke coming out the exhaust when driven on to flatbed Big Cry
Post #143262 27th Sep 2012 10:51am
duka
seems it was an engine shut down valve which was faulty, didnt get to speak to mechanic as he's out on a test drive, but aleast it's not turbos Razz
Post #143499 28th Sep 2012 11:56am
thats good news ...so back on the road later today then... Thumbs Up ... - .- -.
Post #143500 28th Sep 2012 11:57am
ebajema
Engine shutdown valve as in a valve that stops/opens the fuel flow to the engine ??
Had that with a Peugeot 405 once, the engine kept running after switching it off (the rubber seal failed. so fuel kept going towards the engine). Had to clamp the fuel hose to get it to stop till I fitted a new valve Smile Sounds like your problem is the opposite, the valve not letting enough diesel through to drive normally. MY 2010 5.0 SC Galway green and sand interior!!
Post #143503 28th Sep 2012 12:03pm
