Home > Technical (L322) > SOLVED - how to clear check brake pad message
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Hi,
Just done rear pads, fitted new sensor and still have error message. Will it clear itself in a few miles or do I need to disconnect battery ? It's just niggling me that its still displayed and the fact that the sensor wires at the car side of the connector are very fine and getting a bit brittle no doubt now 10 years old. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #163692 11th Jan 2013 2:57pm
Must have a broken sensor wire or poor plug connector somewhere
Post #163704 11th Jan 2013 3:22pm
woodchopper23
I hope not... I cannot be bothered fanny ballsing around getting behind the wheel arch liner to get a good look at the connection MY2010 TDV8 Vogue Ipanema Sand
Post #163726 11th Jan 2013 4:20pm
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
If you go onto bimmernav it tells you on there Thumbs Up gone fishin'
Post #163727 11th Jan 2013 4:24pm
woodchopper23
Hi Andy, what's bimmer nav ? MY2010 TDV8 Vogue Ipanema Sand
Post #163730 11th Jan 2013 4:32pm
http://www.bimmernav.com Thumbs Up ====================================
Post #163731 11th Jan 2013 4:37pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Something to put in the wiki? Smile
Post #163736 11th Jan 2013 4:42pm
dumb question, but whats the bimmernav site got to do with the brake pad sensor problem.... ... - .- -.
Post #163739 11th Jan 2013 4:48pm
Question Question Question
Post #163761 11th Jan 2013 5:52pm
daveo
try unplugging the sensor on the rear, V8 facelift Range Rover Autobiography 22" wheels.
Post #163769 11th Jan 2013 6:15pm
You checked the front ones as well just incase? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #163777 11th Jan 2013 6:33pm
woodchopper23
Ain't checked the front one. Suppose I should , although front pads seem fine. Will update tonmorrow. MY2010 TDV8 Vogue Ipanema Sand
Post #163779 11th Jan 2013 6:37pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Try ignition pos 2 for 30 seconds or until the warning liht goes out then ign off then start car .... Maybe an urban myth but a few BMW owners report that works for this issue.
I'm expecting the same as I have to do my rears this weekend.
Post #163789 11th Jan 2013 6:52pm
daveo
i thought the light come after doing the rears... V8 facelift Range Rover Autobiography 22" wheels.
Post #163792 11th Jan 2013 6:57pm
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
When I replaced my pads (all round with new sensors) the message went with no need to reset anything!
As above, check the sensors and there wiring front and rear....
Post #163800 11th Jan 2013 7:07pm
