Home > Technical (L322) > Door lock problem - serious!
Thumbs Up ... - .- -.
Post #166489 22nd Jan 2013 11:23am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I bought 3 bottles of the Gummi Pfledge stuff before the snow came, but unfortunately they appear to have gone missing in the post. They'll probably arrive when it's summer ...
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #166493 22nd Jan 2013 11:33am
If it is the frozen lock, and only if, chances are the others are OK simply because they don't get the frequency of use that the drivers lock gets, which is why it's probably dried up and therefore frozen.
Should you manage to open the door, liberally spray the lock mechanism (not the key hole but the mechanism on the door jamb) with silicone spray or white lithium grease and really try to get it inside as much as possible. And spray the stainless catch on the B-pillar as well just in case the latch freezes (or has frozen) to that.
And, as Stan said, sort your rubbers out. If you don't have any Gummi Pfledge to hand at the time, use silicone spray or some vaseline or just something to lubricate and soften the rubbers to prevent freezing.
The heater suggestion is a solid one. Might be an idea to put it on a timer switch to go on, say, an hour before you need to use the car. That'll give it good time to warm up everything nicely and to soak the heat into the panels and therefore the lock mechanism. Si. <This is my name.
Post #166516 22nd Jan 2013 2:29pm
benjj
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
You wonderful men Smile
It was indeed frozen. Didn't even need to put warm water on when I got home just now, it worked right away!
I've siliconed the seals, inside the key hole and around the handle. I've also put some spray light white grease into the actual lock mechanism. Will order some Burt Whatzizname Gummi Bear Spray pronto!
Thanks again. Thanks Censored for that!
Post #166584 22nd Jan 2013 6:32pm
TheAllSeeingPie
You're welcome to pick up a bottle of Gummi Bear spray from me if you want? Looking at how far it goes 3 bottles was excessive ...
Post #166727 22nd Jan 2013 10:45pm
benjj
Terrific, thanks! Where abouts are you? Quite happy to pay of course.
Post #166830 23rd Jan 2013 10:09am
TheAllSeeingPie
I'll PM you Smile
Post #166864 23rd Jan 2013 11:14am
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Glad it worked dude
Post #166904 23rd Jan 2013 1:30pm
same here when wifey's XK convertible stays outside at night - you get frozen door rubbers and you cannot open the door the other day Yawn All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #166908 23rd Jan 2013 1:38pm
