![]() | Home > In Car Electronics (L322) > 07 rear door panel removal |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 ![]() ![]() ![]() |
If its the same as an 04
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Video link in the wiki |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263 ![]() ![]() ![]() |
Ive bloody tried this 4 times now! mine is slightly different from the video, on mine there are 3 screws, and once removed, pop the fixings.. but there seems to be something in the middle of the panel holding it to the door,VERY FRUSTRATING!! should be a simple repair job, once removed. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Lift the trim when its hanging off as its sat on a large plastic pop clip in the middle that often will not pull apart, but lifting the panel slides it out of the panel... Remember to pop it off with a trim tool and refit it to the door card before you re-install |
Right..at last, someone who`s done one!
Bump! |
Have you removed the screw in the door handle?
On mine, an 07 TDV8 vogue with logic 7 sound, the panels are different from the TD6 i think.
Here is an image from the 07-10 workshop manual |
You need to remove four screws in total 3 in the cars itself and the 4th is hidden behind the LandRover badge... |
HOORAH!!!!!
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
I struggled with the central black clip today, took all 4 door cards off and applied copious amounts of sound deadening. Even did my lower tailgate while I was at it |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
is not the 2007 s/c very quite anyway mr p. ... - .- -.
It's already very quiet, but I had some extra soundproofing foam left over from another project so decided to fit it. The car is amazingly quiet now, even with the bonkers exhaust on it. |
