![]() | Home > Maintenance & Mods (L322) > 07-09 indicator stalk to fit a pre-06? |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
It's a function of the Light Control Module I think and not a hardware item. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35836 ![]() ![]() |
if your lcm hasnt got that feature then it wont work, even the IIDTool wont switch it on if its not option on the ecu.. ... - .- -.
The three flash option is programmed in the ECU (the LCM in this case) as far as I know. Maybe if you upgrade the LCM or the LCM software you can get it. I turned it on on my car and it didn't work. I do plan to update the LCM software if I get my bloody flash file loader working and there is newer software available. If that works, I will let you know whether the 3 flash works.
Thats why RR drivers from 07 on have more friends |
Are you sure it's in the LCM ?? I know that enabling this on a Discovery 3 requires a flash of the Body Control Module. |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 ![]() |
Get a intravee its an option in there |
its a most system so afaik the intrevee wont work. ... - .- -.
Does the most cover all the ecus as I thought it was only the nav audio im thinking the Ibus is still there |
done a search on here re intravee and all of the threads refer to the pre touch screen ranges.. ... - .- -.
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 ![]() ![]() ![]() |
Thanks for the replies.
Get an 07> M.Y. car, not only will you get a new car & three flash indicators but you'll also get some more friends... See above ![]() ![]() ![]() ![]() Craig ![]() |
