Home > Maintenance & Mods (L322) > Question after 2006 facelift conversion |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1652 |
Hi Folks,
6th Apr 2013 9:17pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
they are cornering lamps, they come on at low speed when turning into a drive ect but will not work with your car.. V8 facelift Range Rover Autobiography 22" wheels.
6th Apr 2013 9:22pm |
Cool - THanks both - I'm happy if its the cornering light and I know It won't work but just wanted to make sure. Ash
6th Apr 2013 9:23pm |
Dave - Did you do the 2006 upgrade on yours..? Any clues on how to plumb in the washer jets for the lights.? Ash
6th Apr 2013 9:24pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
why not wire it up to the side lights ,might look ok.. ... - .- -.
comports, from memory you have to link to wires togeather behind the head lamp, let me look for the post to find out the colours, unless stan beats me to it. V8 facelift Range Rover Autobiography 22" wheels.
6th Apr 2013 9:48pm |
Its the plug with four wires ands its the brown/black wire and the pink/grey wire dont forget it will only work with the lights on and squirts on every sixth squirt of the windscreen
6th Apr 2013 9:52pm |
Thanks Dave - I'll give it a go tomorrow but think its wired in correctly.
6th Apr 2013 9:54pm |
the old washer bottle does not have the hi power washer pump for the 06 headlamps but you can get away the the original headlamp washer, what you will find is the washer on the shorter hose squirts stronger but if you use one of those fish tank air pump clamps and restrict the hose you can even them out, V8 facelift Range Rover Autobiography 22" wheels.
6th Apr 2013 11:03pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Thanks! I always wondered what that was and why no switches seemed to turn it on. |
7th Apr 2013 12:40am |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 365 |
will it be possible to link up the cornering light with the main beams or the fog lights |
7th Apr 2013 5:40am |
Right Dave,
8th Apr 2013 7:02pm |
Calling Daveo....!
8th Apr 2013 7:54pm |
Semi panic over. Did the lock to lock and using IID cleared the faults and all ok again I think
8th Apr 2013 8:08pm |
