Home > Technical (L322) > Paddle Shift?
Page 2 of 7 <1234567>
Emperor Mong
Gazellio wrote:
As stated above I am pretty sure they all have paddleshift now but the S/C retained the Stick rather than dial for reasons of sportiness.
And the S/C has the old gearbox - not the new 8 speed.
Post #47562 26th Jan 2011 8:52am
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
The "old" gearbox is just great for that lazy 5.0 s/c Thumbs Up
So, dan_uk_1984, can I just walk into LR and buy the wheel, or is there other hardware required?
Post #47564 26th Jan 2011 9:03am
dan_uk_1984
Both the ZF 5 speed and 6 speed are steptronic boxes. They are fully electronically controlled, rather than the "auto's of old". Classed as a Semi-Automatic. (even the P38 was electronically controlled and there was a mod to use the cruise or stereo buttons to change gear)
It's pretty much the same tech that goes into BMW cars - so the paddle shift feature out of BM's fits our scenario perfectly. The Rover 75 and MG ZT could also have the retrofit, which was at least a little more fitting.
There is lots of info all over the interwebs.
Post #47588 26th Jan 2011 10:47am
Baben
Can't find anyone thats actually done the paddle-shift retrofit to an L322 though. Not even BBSSpy
Post #47594 26th Jan 2011 11:35am
scene247
Quote:
Gaz wrote: "I drove the 4.4 TDV8 for 90 minutes and used the "Paddle Shift" system so I know its there! You can use either paddle to shift up & down (Forward or back) and hold the right paddle in for a second or two to change back to "Drive"..... "
Gaz,
Really? I have the 2011MY 4.4 TDV8 and the paddles are marked - and + and only pull towards the wheel. Didn't know just one could control both up and down shifts. I'll have to check later on as that's really quite interesting. Agree with the other part about returning to drive.
These are very useful for downshifting without having to floor it for kickdown. Also was very good for use in the snow to slow the car without braking, only braking at last minute to come o stop.
I was told these were added as with rotary selector no way of manually shifting. 2010MY had the stick that could be used to shift.
Post #47614 26th Jan 2011 12:18pm
kkqd0298
United Kingdom 2011 Range Rover Autobiography TDV8 Java Black
Have a look at the disco forum as several people have converted their discos. TBH It works well with the 8 speed box, but not sure if it is worth it for the 6 speed. *Gone* Discovery3 HSE
*Gone* MY10 RangeRover TDV8
Freelander for OH
MY11 Range Rover 4.4 TDV8 Autobiography Black
Post #47626 26th Jan 2011 1:36pm
Baben
Yes I know. I did the first Disco3 paddle shift installation ever, thanks to wiggs and Colin. I was just hoping the FFRR would not need splicing into wiring looms etc
Post #47627 26th Jan 2011 1:38pm
dan_uk_1984
I think that's because most owners of RR's haven't thought "you know what I think this car really needs is paddle shift"
You don't need to add new cables AFAIK because that's the benefit of digital over analogue signals. You just need 1 cable to carry the data.
Here is some info on the retrofit for the early X5's (if it can be done on an X5 it can be done on a RR)
http://www.tayam.net/x5/smgwheelonx5.htm
More info, more complicated:
http://forum.e46fanatics.com/showthread.php?t=63211
Post #47638 26th Jan 2011 2:34pm
Baben
Thanks Dan
When I have a break from travels I will open up the RR and see what connections are available. If it is anything like the D3 then there is a bit of splicing involved where the connection to the gearbox ecu comes into the picture.
A big question is whether there are any circuits available in the "clock spring" behind the steering wheel, and if not will have to use something like pete bell's RF solution
Post #47762 27th Jan 2011 4:05am
Dogman
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
On the BMW E46 you just needed to tap into the signal lines from the gearstick/lever (i.e. to replicate the contact closure when stick is pushed forwards & backwards). A bit heath-robinson but it was an easy retrofit, worked and was reliable.
I had an SMG M3 which has the paddles and found most of the time I just left it in 'Auto' but then again that was an SMG as opposed to a 'proper' automatic and unless you throttled off during upshifts it did change gear like you were on a track (which SWMBO & my 5 year old were not that appreciative of).
Also I much prefer the 'Left pull for downshift / Right pull for upshift) rather than the push/pull on either paddle scenario and finally yes we all like out toys but in reality is the FFRR a car that needs the paddles?
Having said all of this, if there was a bolt on replacement FFRR s/wheel with the paddles I'd have to check up the price and make an informed decision, as I say we all like our toys eh Thumbs Up
Post #47785 27th Jan 2011 10:12am
Jsb
http://cgi.ebay.co.uk/Range-Rover-L322-Ful...33647b1f3b
Post #47814 27th Jan 2011 1:42pm
Jsb
i just bought a new wheel, ebay 180 delivered, wanted the smooth leather and mine looked worn. It has turned up and has the paddle shifts.......now i want them to work! will fit the wheel without wiring them up, bit beyond me i reckon.....but if anyone cracks this please let me know.
Post #47968 28th Jan 2011 1:44pm
scene247
Dogman, Gaz,
I have had a look, and play on my car and indeed it is left downshift (-) and right upshift (+) only. No push/pull on either paddle, they only pull and have single control each. Gaz, don't know what model you got to drive - interesting though.
The paddles are not used often in everyday driving for me either.
Post #47978 28th Jan 2011 3:18pm
Dogman
Sooooo much better than the push/pull (as I'm sure Porsche owners will confirm)
Post #47980 28th Jan 2011 3:22pm
Baben
Confirmed with "The Large One" (on D3 forum) NIck at Yeovil LR that the paddles for the L322 are available separately. I just have to figure out how to connect them then....
Post #48057 29th Jan 2011 7:22am
