Home > Technical (L322) > Tyre Pressure Monitoring Problems |
How about you just get it fixed so that it works as intended?
31st Mar 2010 3:06pm |
504cash Member Since: 31 Mar 2010 Location: Reading Posts: 11 |
Well nine of my visits to the dealer have been under warranty so I havent had to pay,
31st Mar 2010 3:09pm |
Ask them to remove all sensors and the ECU - then I'll buy it off you. |
31st Mar 2010 3:25pm |
do you think it will still comee up on the instrument display "tyre pressure monitoring fault" even with sensors and ecu removed ? |
31st Mar 2010 3:51pm |
I have a feeling that if you disconnect the ECU then you wont get the error message as it's the ECU that sends the message to the instrument pack.
31st Mar 2010 4:00pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
Won't help , but I do sympathise. Biggest heap of crap invented. Just discourages proper regular visual checks of tyres. Throws so many faults it creates a "cry wolf" scenario.
31st Mar 2010 5:11pm |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 |
Mine is disconnected - done by the previous owner; don't know how, but I do have normal tyre valves.
1st Apr 2010 7:56pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
Mines going back to the dealer in two weeks to have it sorted, been faulty since I got the car, 4 months now Discovery 4 HSE
1st Apr 2010 10:40pm |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 378 |
FYI: I was told by my dealer that if tire pressure monitors have been removed and reinstalled more than
2nd Apr 2010 4:31pm |
DO you know which dealer this was ?? Ill call them and ask them how !! thanks |
3rd Apr 2010 11:33am |
Stratstone of Mayfair I believe. They undertook all servicing prior to me buying the car. Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD! |
4th Apr 2010 1:09am |
Waiting to hear back from Stratstone Technical department..
6th Apr 2010 4:29pm |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 |
does anyone know what the tolerance of the TPMS system is? I found that if the tyres are too hard it also causes a "system error" (no specific wheel indicated). I played around with pressures, but if you deviate by more than about 10kpa either up or down, it seems to get the system error.
7th Jun 2011 2:03pm |
sportin Member Since: 12 Mar 2011 Location: USA Posts: 26 |
My spare has the fault.......dealer offered to disable the monitoring for it, for $35.do not disconnect any ecu.....you will cause other problems 2006 RR 4.4 HSE
29th Jun 2011 5:22am |
