Home > Technical (L322) > 2007-2009 door card panel LED lighting set up
Flashman
OK, so I got hold of the new style door cards and installed them on my 2004. I have just driven the car at night noticed that the door cards light differently.
The drivers door illuminates the door handle scoop, release pull and storage bin, but the passenger door only illuminates the release pull and storage bin.
The rear door cards only illuminate the release pull, but not the storage scoops or handle scoops.
Is this normal, or do I need to remove the panels and check the LEDs on the three door cards? Tom
Current Drive
Previous Drives
Post #196912 29th Jun 2013 11:27pm
daveo
can you see the led in these positions,are they physically there....what did you do about the air bags in the doors.. V8 facelift Range Rover Autobiography 22" wheels.
Post #196937 30th Jun 2013 9:33am
Flashman
There are holes for the LEDs and the wiring seemed to be there, I forgot to check the LED positioning before installing. I might take a panel off today to check.
I did not notice any airbags or extra wires (other than the tweater speakers all had spare wires coming off the fronts and no connector plugs for the rear) For the rears I just jammed the wires into the connector and it seemed to work, at least for the moment. Tom
Current Drive
Previous Drives
Post #196938 30th Jun 2013 9:47am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Pre-2007 the airbags are in the doors, post-2007 they are in the seat (hence the loss of upper back adjustment). So essentially you've removed your side impact airbags.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #196948 30th Jun 2013 10:32am
Flashman
Just opened up the panel and you are right the door frame has the airbags for the front doors just next to the lock pin, on the old panel there is a special membrane with netting to split when the bag detonates, the new panel does not have one due to the airbags being moved to the seats. I wonder if the newer seats could be fitted and the airbag wiring loom diverted from the door to the seat.
The newer door panels are much better looking than the old ones, and seem to be more comfortable.
I have disconnected them for the moment so as not to cause an issue with the panel. Tom
Current Drive
Previous Drives
Post #196955 30th Jun 2013 10:57am
Andy
Airbags where fitted as standard, have to work.
Post #197044 30th Jun 2013 8:58pm
