Home > Maintenance & Mods (L322) > Replacing belts on supercharged |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
Is it the plastic intake tube you're seeing near the rad? It's two jubilee clips and a tight fit pcv return hose. Easily removed, bit of a to get back on. You can do the belts with this removed and it's not torque sensitive when you put it back on. You can remove the intake plenum but that's a bit of a sod and not necessary. Be prepared to skin knuckles doing it though ...
4th Aug 2013 3:39pm |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 220 |
Thank you for your reply.
4th Aug 2013 5:13pm |
You have to unbolt the radiator and remove the viscous fan to do the belts. It's an arse but once done the belts are quite easy.
4th Aug 2013 5:40pm |
Agree. That presumably means draining the aircon as there is pipe across the top of the rad. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
4th Aug 2013 6:02pm |
