Home > Maintenance & Mods (L322) > Tailgate Headlining 'Loose' |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Hi,
24th Oct 2013 6:17pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Mine is the same - was gonna get some double sided tape onto the edge but never got round to it. |
24th Oct 2013 7:43pm |
Main dealer was going to do it but said didn't have time as was a full headlining off and back on again which seems a bit OTT and if so... It's not that bad! |
24th Oct 2013 9:21pm |
There is a clip in the centre of the roof lining... just a couple of inches back from the rubber seal... It slides into a reciever bonded to the roof liner then that intern pushes into a hole in the roofskin
24th Oct 2013 11:04pm |
Brilliant. Thanks Craig, will look later |
25th Oct 2013 6:32am |
Let me know if it works? Ill put the bill in the post sir |
25th Oct 2013 8:43am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
25th Oct 2013 8:50am |
every little helps... |
25th Oct 2013 8:54am |
Cam-Tesco-Craig .... ====================================
25th Oct 2013 1:01pm |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
^^^ Si. <This is my name.
25th Oct 2013 1:13pm |
Ahem so I located and unclipped the clip! There is a black plastic sheath attached to the inard of the headlining and I managed to free it from the white plastic clip that is fixed into the metal roof... There is no play forwards or backwards with the headlining. So how does the black sheath slid/ clip back onto the white clip please? |
25th Oct 2013 3:09pm |
Found this info by searching the forum re 'headlining' keyword:
26th Oct 2013 6:33am |
I have a similar problem and my clip is broken.
26th Oct 2013 6:55am |
