Home > Maintenance & Mods (L322) > noise dampening
td6vogue
noise dampening
is there anyway to reduce the noise from the td6 while accelerating
its quite a racket
sound dead proofing of sum sort
i heard the tdv8 has extra insulation in the engine bay
Post #229802 17th Dec 2013 4:06pm
It's also a much quieter engine.
Try turning the stereo up. Smile
Post #229808 17th Dec 2013 4:11pm
the tractor sounding engine of the td6 is indeed noisy..you could stick extra sound deadening in the engine compartment but i dont think it would make much difference..
the tdv8 is a different engine and is quieter.. ... - .- -.
Post #229811 17th Dec 2013 4:15pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I quite like the 6 cylinder rumble Smile
Post #229817 17th Dec 2013 4:32pm
I don't. It's a racket - not a nice noise at all.
Post #229819 17th Dec 2013 4:35pm
td6vogue
can the sound damper be fitted to a td6 from tdv8
Post #229845 17th Dec 2013 5:28pm
The TD6 has an active engine mount to try to counteract some of the noise , I don't think the TDV8 even bothers.
The last of the TD6's are a little better but its hard to see what an individual could do , and why is the same engine so much quieter in the soccer mum X5 ? 2008 MY Supercharged
Post #229961 18th Dec 2013 1:13am
DMRR
Fit some offroad tyres and your problem with engine noise will go away instantly ... you'll be spending your days escaping the swarm of bees :lol:
Post #229963 18th Dec 2013 1:16am
^ Laughing
I must have had one of the last TD6 engines in my SE. I always thought of it as really quite quiet inside the cabin. Absolutely no tractor noises at all. Did the later SE's have more sound insulation? Previously..
Post #229977 18th Dec 2013 8:53am
Richcl
^ I agree.
Maybe on first start up until it's warm their is a little diesel clatter (if that) but afterwards sounds fine, reminds me off a BMW petrol 6 cylinder engine.
I'd be sitting in another TD6 to compare engine noise, maybe some sound proofing is missing?
Post #229980 18th Dec 2013 9:17am
td6vogue
been in other td6's andthe same
its ok when moving but the initial pull off is nasty
Post #230110 19th Dec 2013 10:06am
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
I'm fitting a full Dynamat sound deadening kit in late Jan so you can wait and I'll tell you if it works.
It's not cheap but hopefully will make a huge difference.
Also engine oil and gearbox oil change might help quieten your beast
Thumbs Up Bushy
2003 RR Vogue Monté Carlo Blue
Post #230115 19th Dec 2013 10:26am
Googsy
In my early days when I had a Citroën 2cv I glued a tog 15 duvet to the underside of the bonnet Laughing Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #230120 19th Dec 2013 10:34am
Bushy513
Rolling with laughter Bushy
Post #230123 19th Dec 2013 10:36am
td6vogue
just had oil change
please update with the dynamate upgrade once done
Post #230129 19th Dec 2013 10:49am
