Home > Technical (L322) > Not a lot of heat in my L322 Thermostate? Hot and cold hose |
MariusRR Member Since: 19 Mar 2013 Location: Oslo Posts: 98 |
Anyone? Thinking about just changing the thermostat. Labour is about 150-200 pounds an hour. a thermostat is about 120, and I can change it myself. |
24th Jan 2014 5:56pm |
jambo27 Member Since: 03 Dec 2013 Location: Staffordshire Posts: 124 |
Check your pollen filter - had a similar problem when i had my RRS. Took the filter out and it was almost blocked solid. Replaced it and had a lot more heat and quicker warm up time. |
24th Jan 2014 7:41pm |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 340 |
24th Jan 2014 9:13pm |
Icecold still. Tried topping off and bleeding the system. No luck |
24th Jan 2014 11:39pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Had a blocked pollen filter in my 7 series airflow 100% better now changed and I think the 7 series and early FFRT share a lot of parts/design in the engine and cooling areas There is a difference between knowing your sh!t and knowing you're sh!t
24th Jan 2014 11:40pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
If the pollen filter was blocked would the car not heat up quicker inside? If there is no cold air coming in it will just recirculate the air in the cabin will it not? Could it be a FSR fault? Previously..
24th Jan 2014 11:45pm |
Its completly cold now. Not lukewarm etc. But blowing.
24th Jan 2014 11:50pm |
Heater valves were a problem on the BMW not sure if the same part on the FfRr There is a difference between knowing your sh!t and knowing you're sh!t
24th Jan 2014 11:56pm |
Waterpump? Previously..
24th Jan 2014 11:59pm |
Waterpump? Why? Isn't thermostat more likely? |
25th Jan 2014 12:02am |
If the thermostat was stuck open it would be very slow to heat up, but it would heat up eventually. As you have no heat at all the water must not be getting to your heater matrix. A valve must be stuck or the water is not circulating is my thoughts. Previously..
25th Jan 2014 12:08am |
Possibly the Heater matrix valves.
25th Jan 2014 12:26am |
Will the blower blow if the FSR is shot? |
25th Jan 2014 12:27am |
How do i fix this? Possibel to fix so i can Get heat going back down the mountain? |
25th Jan 2014 12:33am |
