![]() | Home > Technical (L322) > Fanbelt/ Waterpump Issues |
| T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936
Was it the pump that caused the belt to go in the first place? Ian |
| Dazzler Member Since: 09 Sep 2013 Location: West Sussex Posts: 34
I hope so?? |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Any idler pulleys which may have seized. There is nothing that can't be fixed with a hammer😜😜
Changed them mate all come in the Gates Kit including the Fanbelt |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
The water pump may spin freely if the impeller had seized and then sheared . 2008 MY Supercharged
Ok Thnks for that |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
I don't tknow the td6, but could it be that the air con clutch came in, and the compressor is seized! try turning the inner part. there is a 12mm nut I think in the middle. should turn ok with belt on, etc.
Evening Alol,
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020
Did you find out what it was after all? |
