![]() | Home > Technical (L322) > L322 gaff (plea for help) &weirdness (plea for explanati |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
a) erm... took the passenger seat out for something yesterday, and the airbag light won't go out... Got a BMW lead and an OBD2 lead - is there any free software I can use to reset it? I tried disconnecting the battery for 15 minutes to see if it would reset, but it didn't
(a) don't know
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
a) navcoder.....use forum search
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
I had to register navcoder to get it to do anything but read things.
Navcoder still needs to be registered & paid for. ( I know 'cos I had to move it to another laptop, and Jochen is still keeping a tight rein on things, even though he did my transfer for free!)
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
Hawkeye resets airbag warning lamps |
Noted! ![]() (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
I *thought* navcoder, as I have that, but couldn't find it in there. Will search forum for it before I go any further ![]() (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
Sorted my NavCoder problem and the airbag light is now reset |
Care to share solution ? .
Sorry Joe... I used the singe module code reset on the AB module to clear the fault codes Tym
jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156 ![]() ![]() |
Just a question .
NavCoder is only 20 Euros if the IID won't work. Tym
@jaybear, the iidtool can clear an airbag error... ... - .- -.
