Home > Technical (L322) > Help on diesel leak
Page 2 of 3 <123>
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
Well im not 100% sure the pump is leaking as im still confused as to why it stops leaking after 5 mins or so on 1st start up of the day i cant see it dripping on any other start up untill the next day when its been stood all night ive done the jubile clips on the pipes as 1 was loose so i did both it appers to be leaking below them pipes from the bottom of the cover that has the 4 torx screws
Post #469280 19th Feb 2018 7:10am
holidaychicken
Maybe it seals better once it warms up but just a guess
Post #469284 19th Feb 2018 9:01am
Johnsd1v8
I thought along those lines the pressure pushes the seal tight
Post #469287 19th Feb 2018 9:47am
Paul thornton
Have a read of This, it will tell you everything you need to know -
https://www.landyzone.co.uk/land-rover/td6...ir.307483/
Post #469304 19th Feb 2018 11:41am
Johnsd1v8
So ive found a ivene cheaper one with no surcharge exchange or anything
Post #469311 19th Feb 2018 12:15pm
Johnsd1v8
Cheers paul so it looks a fairly straight forward job
Post #469313 19th Feb 2018 12:17pm
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Leak
Pay attention to this hose. Due to the heat and the time it crack and the diesel passes through it near the injection pump.
It happen to me two weeks ago. The Origina part (WJP001080) is very expensive 132€ plus VAT. I replace it with a common fuel hose directly from the filter to the pump.
See the picture
http://www.fullfatrr.com/gallery/albums/us...0copy.jpge
Post #469316 19th Feb 2018 12:56pm
Johnsd1v8
The link wont open pal?
Post #469317 19th Feb 2018 12:59pm
A.Pires
Leak
I never knew how to add photos here. Go to my gallery the image is there[/img]
Post #469318 19th Feb 2018 1:02pm
Johnsd1v8
Yep i know the pipe you mean pal ive just done the jubilee clip on it where its goes on the pump i will check it further thanks where abouts did yours crack on the pipe itsself pump end yes
Post #469319 19th Feb 2018 1:05pm
A.Pires
Leak
Mine cracks near the pump. The clamp is a BMW one and is very strange to remove it. It must be done with a plier. Probably LR have a special tool for.
I replace the clamp with a normal one.
The hose that I use is a normal one with a inner of 8mm for fuel which you find in a rubber shop or automotive shop.
and goes directly from the fuel filter to the pump.
If you want I can take a Picture for you
Post #469320 19th Feb 2018 1:11pm
Johnsd1v8
I know what you mean about the clip it was a fight to get that off and i did it in the dark so i didnt check the pipe but a picture of your cracked one would be a help thanks
Post #469322 19th Feb 2018 1:24pm
holidaychicken
Any update on this one ?
Post #474279 29th Mar 2018 5:43pm
Johnsd1v8
Well i havent toutched mine yet but it appears to have stopped leaking
Post #474282 29th Mar 2018 5:56pm
holidaychicken
I think mine has done the same although i have stopped looking Very Happy
Post #474286 29th Mar 2018 6:43pm
Page 2 of 3 <123>
