Home > In Car Electronics (L322) > 2010MY Amp Upgrade
Page 1 of 3 123>
comports
2010MY Amp Upgrade
Oh wise and worldly lot...
In my old 54 Plate, the very kind Baris performed an amp upgrade for me and it made a massive difference to the sound. Does anyone know if a similar upgrade is available for the amp in my 2010 MY Full Fat..?
Any one else done anything in this area to upgrade the system??
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #470046 25th Feb 2018 8:45pm
is it not loud enough for you Ash? ... - .- -.
Post #470076 25th Feb 2018 10:10pm
comports
Actually - No Stan
It could be but it distorts quite a lot at those levels. I could do with a bit more 'umpfh' with bass etc at higher volume..
Just not sure whats possible without ripping it all out and replacing with aftermarket (which I don't want to do) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #470077 25th Feb 2018 10:13pm
wait till you get older...AM sounds good then Shocked Laughing
just a thought, is there a difference between FM and DAB cos there might be a problem with one or the other.. ... - .- -.
Post #470080 25th Feb 2018 10:18pm
GGDR
Ash I take it you have the std Harmon Kardon not the 1200w?
the 1200w is V E R Y adequate, I think I read someone here upgraded.
Give the search button a spin..
Greg Cheers, Greg
Post #470082 25th Feb 2018 10:31pm
mjdronfield
I had the stage 2 Baris upgrade in my TD6 and it was well good.
I have the standard 900w in my Vogue SE and want more....
I got the part number for the 1200w amp but need to know if it’s a straight swap, wiring wise.
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #470088 25th Feb 2018 11:27pm
mjdronfield
According to the reading, there are 5 extra speakers in the 1200w system, but they been a bit cheeky, as there are 5 of the existing speakers that have a extra coaxial speaker in the same unit....centre dash....rear door lowers and the 2 at the side of the top tailgate, which only seem to work with the surround on, which is not suitable for normal music CDs..... so I recon the amp swap would give you pretty much an HD system as per the top option.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #470090 25th Feb 2018 11:49pm
comports
oh no - now you've stirred it up..! Laughing
How do I tell if I already have the 1200w system or not.? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #470111 26th Feb 2018 9:05am
GGDR
1200w system will have an HD symbol in the speaker grille Cheers, Greg
Post #470117 26th Feb 2018 10:03am
comports
thx - Thumbs Up
will check tonight... Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #470122 26th Feb 2018 11:24am
mjdronfield
As above...I thought they said Logic7HD on the speaker grilles and had a silver trim round the bottom speaker as below.......
.....but when I’ve just looked now, there are some on the trader without the HD symbol but the silver trim on the lower speaker.... mmmmm
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #470172 26th Feb 2018 6:39pm
mjdronfield
I also believe the amp is a better quality amp, not just louder.
https://techcrunch.com/2010/08/30/harman-k...nd-better/
https://www.autoevolution.com/news/land-ro...23972.html
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #470173 26th Feb 2018 6:44pm
mjdronfield
More info from last year.....
http://www.fullfatrr.com/forum/topic43436.html?highlight=1200w 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #470174 26th Feb 2018 6:46pm
GGDR
The silver trim means it's a autobiog. Nothing to do with the sound system.
HD was not std on AB's, at least for 2010 and 2011 It was std Westminsters though. Possibly std on 2012 AB's.
. Cheers, Greg
Post #470175 26th Feb 2018 6:47pm
mjdronfield
That makes more sense then... the ones I’d seen so far always had both together.
I know the part number in the pic above is the 1200w amp, but there may be others.
I don’t know the part number of the standard amp though.
Need more info to ensure the correct amp is purchased, and I think you then need a diag tool to set your car options in it, but again, this is not confirmed..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #470179 26th Feb 2018 7:41pm
Page 1 of 3 123>
