Home > Technical (L322) > Steering wheel reach
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
My steering wheel reach adjustment hasn’t worked since I’ve had the car. Whilst trying to sort another issue with brake lights tonight I found this dangling around the peddles.
Is this going to be an easy repair by reattaching the reach motor or is it a more complex job?
Post #478523 15th May 2018 9:23pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
There are 2 motors - one for the in/out and one for the up/down. The in/out motor is held on with a white plastic clip that easily breaks and can cause the motor to fall off (whcih looks like what has happened to yours) - You can't get the plastic clip, though i have seen people fabricate something to fix this problem. The other problem with this motor is the black plastic nut can strip its thread - so check that too.
The up/down problem is caused by something different - the lugs that hold the (brass) nut can break off.
 Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #478555 16th May 2018 10:08am
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Mine did the same early last year. As said, you can't get the white plastic mount separately. I used a couple of heavy duty cable ties to lash it back into position, and touch wood, it's been fine since. Is a very uncomfortable job to do though! 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #478601 16th May 2018 6:36pm
SidewaysMatt
Like this... 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #478602 16th May 2018 6:43pm
RRV78
Is this not the bracket I need?
https://www.island-4x4.co.uk/bracket-genui...28495.html
Post #478642 16th May 2018 10:12pm
Zebedee
Well I'll be.....
That does look like it - I've never seen just the clip on sale before. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #478717 17th May 2018 8:27pm
RRV78
I was on a well known auction site and happened to see one on there and was showing the land rover part number on the packet so googled it and this was cheapest place I found it.
Post #478718 17th May 2018 8:31pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Thats the bracket you need QYH500030 - always been available, although not everyone stocks it. Although these days its a lot more expensive than it used to be - used to only be a fiver!
You will need to rummage around at the back of the carpet though for the steel rod which drives through it. It will be there- I found it sat on top of the carpet behind the pedals. (just spotted in your picture the rod is still in place)
You'll also need the force of hercules to put it in and once its in, its not coming out so make sure you have it set up. After an hour or so of contorting and fighting it I realised a long spark plug socket placed over the lug and a sharp tap got it in. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #478738 17th May 2018 10:30pm
