Home > Technical (L322) > Roof rails
bishbosh10
Roof rails
Couple of questions please before I go genuine or poweful UK:
Do the genuine rails require the removal of the little covers on the roof (which I understand to be permanent)
Also, can you get the rail end caps separately? (Probably a question for Dan)
Has anyone used the powerful UK set as they seem good value? https://www.powerfuluk.com/range-rover-l32...-bars.html
Thanks all! Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #479508 28th May 2018 9:31am
ajac8
I have genuine roof bars and they are quality. I have heard some negatives about powerful uk stuff being built down to a budget. would avoid them TBH unless others disagree.
The plastic covers hinge vertically towards the centre pf the car and are not removed. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #479527 28th May 2018 12:01pm
Dolphinboy
I’ve seen gen ones for c.£190 on eBay. The roof caps do have to come off permanently unfortunately.
Post #479555 28th May 2018 7:29pm
or DIY
http://www.fullfatrr.com/forum/topic2798.html Wink .
Post #479556 28th May 2018 7:39pm
nino_nino
or something like this:
,Nino
Post #479586 29th May 2018 10:50am
Crispian22
I threw a set of genuine ones away a couple of months ago......didnt realise how much they are to buy Crying or Very sad
Post #479589 29th May 2018 11:32am
Sandyt
I have the Whisbar ones and the flaps do not have to come off - good piece of kit
http://www.whispbar.com.au/browsebyvehicle...ge%20Rover for info
Post #479590 29th May 2018 11:41am
GraemeC
If you just want bars rather than rails, then the caps do not have to come off to fit the sports bars, they just flick up to expose the bolts
You should be able to pick up a set for circa £50 on ebay
https://www.lrparts.net/genuine-land-rover...r-kit.html 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #479591 29th May 2018 12:02pm
bishbosh10
Thanks all.
Currently going to stick to getting rails as they offer flexibility the fixed bars do not.
Good to know the genuine rails don't need the flaps cutting off.
Depends if I can find some cheap enough though! Laughing Bish.
2005 110 TD5 CSW
Post #479594 29th May 2018 1:12pm
ajac8
Don't confuse bars with rails. Sports bars do not remove the plastic covers. Front to back rails I believe do remove the plastic covers as above. Thumbs Up
I think £50 is pushing it for 322 sports bars. The cheapest I can see today are £110.00. Big Cry 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #479607 29th May 2018 4:47pm
If you are fitting front to back rails for which I understand the roof flaps have to be broken off to fit would it be worth considering drilling holes in the said flaps at the fixing bolt positions so that the fixing bolts pass through the flaps to allow the roof rails to sit down flat whilst still retaining the flaps. If you then subsequently remove the rails, the flaps would still be in place, the holes could simply be sealed with gorilla tape or similar patches. Given the flaps are high up any patches would never be seen, if you have a black car even more so. Thumbs Up
Post #479611 29th May 2018 5:55pm
or grommets
http://www.halfords.com/workshop-tools/gar...ets-9-13mm .
Post #479623 29th May 2018 7:27pm
Even better Thumbs Up
Post #479624 29th May 2018 7:29pm
