Home > Technical (L322) > Next question-grabbing while cornering
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
The car seems to wheel spin the front wheel very easily, when turning, this in turn activates the traction control light briefly.
Just been out for a spin and when cornering hard right, there is a grabbing-like the ABS kicking in.
Do i have a duff sensor or could it be CV related?
Post #503923 4th Feb 2019 4:19pm
GraemeS
Australia
This sounds like the known problem of the centre diff grabbing, for which the cure is flushing the transfer case then recalibrating it.
Post #503959 4th Feb 2019 8:41pm
philip1972
ooooh dear, that sound difficult=expensive Sad
Thanks for the reply.
Post #503960 4th Feb 2019 8:42pm
pld118
How hard was the cornering?
Post #503965 4th Feb 2019 9:58pm
philip1972
Well today I was trying quite hard-I would normally drive like that but at least it was on an airfield Very Happy
It a bit odd really, as I also get front wheel spin quite a bit too (might just be the crap tyres that are worn bald on the edges).
Cheers
Post #503966 4th Feb 2019 10:01pm
GraemeS
Australia
A double oil change for the TC then invoke self-calibration using a diagnostic tool, so not expensive. However if the apparent fault occurs in a straight line then not a TC problem.
Post #503971 4th Feb 2019 10:23pm
pld118
Al sounds very technical GraemeS... The Top Gear evoking airfield image had my lay perspective thinking, "It's a Range Rover not an Aston Martin" Rolling with laughter
Hopefully I'm right Philip and it's nothing serious Thumbs Up
Post #503974 4th Feb 2019 11:02pm
philip1972
So Graeme, I took it out this afternoon and the traction control activated while accelerating (gently) in a straight line......
What does that mean then Question
Post #504035 5th Feb 2019 4:36pm
GraemeS
Australia
Activating on gentle straight-line acceleration - assuming that all tyres are the same size then it is sounding like a faulty ABS sensor that's producing more pulses than it should be. Can you feel the steering pulling one way or the other, suggesting a front wheel that is grabbing?
Post #504080 5th Feb 2019 9:00pm
philip1972
Wasn't being very gentle-if I drive REALLY gently its OK.
If I boot from say 30 it will flicker the traction light. I think, its the left front that grabs.
However, as I said on the PM, the tyres are bald on the outer 1/4 of all tyres and i am beginning to think with the weight of the car its just starting a little slide.
**Please note that I am not a hooligan when on the road-this is happening on the airfield corners** Mr. Green
Post #504081 5th Feb 2019 9:27pm
