![]() | Home > General > moving from disco's to Range Rover help would be appreciated |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3243 ![]() ![]() ![]() |
Isn't that diesel a 3.6L TDV8? |
davmonag Member Since: 21 Oct 2019 Location: Ayrshire Posts: 49 ![]() ![]() |
thanks drf. I did test the suspension. no creeks. all worked as it should apart from I put it into off road height and after 5 minutes it lowered itself. then the fault appeared. With all the input and help I have had on this I will not be going ahead with this one.
it is indeed a tdv8. |
Hi all,
Hello All,
Hi Guys,
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
Good luck |
Hey, its a dealer. Just be brought in from a Landrover main dealer. 1 owner with FLSH plus the last service being a specialist.
Hi Guys,
