|  | Home > Maintenance & Mods (L322) > Tow hitch removal |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136      | Assuming it's the factory one & not modified, that one is just a pin - there should be a clip through it on the other side.
|  29th Mar 2020 7:15pm |
| Keith13 Member Since: 04 Nov 2019 Location: Douglas Posts: 6    | Can,t see any clip on the pin neither can I see a hole in the pin for a clip,the pin is quite rusty though. It might be that the previous owner never fitted the clip to the pin. Blow torch and bigger hammer required I think.It is a westfalia towbar and the hitch is also, part no,s being 329077 and 323051 | ||
|  29th Mar 2020 7:39pm |
| gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163      | If you don't want that height adjustable tow bar, I'd really like it! | ||
|  29th Mar 2020 7:51pm |
| Keith13 Member Since: 04 Nov 2019 Location: Douglas Posts: 6    | Giles, when eventually get it off I will let you know as I dont want to keep it | ||
|  29th Mar 2020 8:00pm |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136      | If there's no pin on the other side - then it's threaded
|  29th Mar 2020 8:18pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Bit of lube on the pin, give it a tap, then tap the lever see if it frees up.
|  29th Mar 2020 9:21pm |
 Lovely, thanks. Really need the height adjustable one for towing a sheep trailer. | ||
|  30th Mar 2020 9:53am |
| Keith13 Member Since: 04 Nov 2019 Location: Douglas Posts: 6    | Alastair - if it is threaded I would,nt be able to turn the pin as the it hits the actual tow bar before I can get a full turn on it, the pin looks the same as your first pic but without the hole for the clip, unless its just rust covering the hole | ||
|  30th Mar 2020 7:16pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Take a picture from the other side for us to take a look   | ||
|  30th Mar 2020 7:21pm |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136      | I guess it's not threaded then   | ||
|  30th Mar 2020 7:22pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | I bought a genuine LR rubber bung to go in the end of the open receiver to finish it off nicely and keep any   | ||
|  30th Mar 2020 7:33pm |
| Keith13 Member Since: 04 Nov 2019 Location: Douglas Posts: 6    | DrRob - Will take some pics tomorrow and put them on here, thanks for all comments so far everybody  | ||
|  30th Mar 2020 7:36pm |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136      | Yep - once the pin is out - then the fun really starts - trying to get the hitch out of the receiver   | ||
|  30th Mar 2020 7:37pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Jack it up with a trolley jack under the tow hitch. That might break the rust   | ||
|  30th Mar 2020 8:09pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
 out. Spayed some grease in there too. Hitch now in shed
