Home > Technical (L322) > Front/ Rear Brake Discs and Pads |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 509 |
I had some trouble (that's an understatement) getting the front disk retaining screws off. Make sure you have an impact driver. I had to get the grinder out.
10th Apr 2021 2:34pm |
Shouldn't be any need to reset anything. The bedding in procedure for the EPB pads is in the workshop manual. 2016 Skoda Octavia VRS Estate
10th Apr 2021 2:39pm |
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 |
Thanks both, hopefully things will come off without too much of a fight! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
10th Apr 2021 5:15pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
If nothing is seized or chewed up from previous hamfisted monkeys it should be very straight forward and obvious. Aprox 3 hours and you should be done.
10th Apr 2021 7:18pm |
Thanks for that tip, everything looks quite clean so hopefully nothing seized or bodged! My existing hubs were rusty so I painted rough areas. Do they all do this so should I paint before fitting new discs?
10th Apr 2021 8:40pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Avoid ECP and use site sponsor Advanced Factors. No contest.
10th Apr 2021 8:43pm |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 274 |
I’ve just done discs pads and rear calipers. Discs from ECP - couldn’t find a better price for Brembo, genuine TRW calipers from Advanced Factors, great price and great service, pads from LR Parts - Ferodo and various fitting bits from Both ECP and Advanced Factors.
10th Apr 2021 9:02pm |
DaleL322 Member Since: 04 Mar 2021 Location: Stamford Posts: 176 |
I have a 2009 3.6 TDV8 and I fitted “Brembo” discs and pads from ECP... worst thing I ever did! They are absolutely terrible and do not provide any confidence while braking
10th Apr 2021 9:24pm |
Speak with Robin at Duckworths, he can offer you Ferodo aswell as a good discount on genuine 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
10th Apr 2021 9:39pm |
Thanks Dr Rob, Jools and Dale, will look at this info looks good way forward. Thanks again. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
11th Apr 2021 1:15am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 841 |
As said dont use ECP I am on my 3rd set of front discs from them and they are crap, use the site sponsors I got a complete kit for the wifes D3 and it is great. No issues what so ever.
11th Apr 2021 9:21am |
Sorry to hear you’ve had a bad experience, I’m no fan of ECP but there is no doubt the discs I got are genuine Brembo and so far seem fine
11th Apr 2021 9:44am |
My ‘Brembo’ pads were made by TWR I think. brembo allow others to make parts under license.
11th Apr 2021 10:23am |
Better have a look round and see what deals are on, Delphi and Pagid seem to be recommended by most. Thanks again. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
11th Apr 2021 12:58pm |
