Home > In Car Electronics (L322) > TV channel stuck on Sky News! 2010 Supercharged
Page 3 of 3 <123
wpo750
United Kingdom 2010 Range Rover Autobiography 5.0 V8 Santorini Black
I've just noticed in mjdronfield's post above where the tuner installation instructions states that a new module requires configuration. With the GAP tool perhaps?
Post #580855 23rd Jan 2021 2:37pm
mjdronfield
Don’t want to cast any more uncertainty.... cos I’m not sure on this, but if the unit isn’t new and come out of another L322 I would imagine it shouldn’t need config. Happy to be corrected... just using logic....
Seems strange you pretty much have the same issue still.... if it needs to be coded, would it not work at all? Thinking aloud....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #580861 23rd Jan 2021 3:25pm
wpo750
Agreed, I just checked the CCF with the GAP tool and they are correct. Hybrid tuner, Variant 1, analogue/digital. I'm not sure what else those instructions could mean regarding configuration.
I'm beginning to consider issues beyond the tuner
Post #580866 23rd Jan 2021 4:55pm
mjdronfield
I can’t think of anything else that would cause the tune option to not work.... if it’s an antenna issue, would it not still tune and then not find anything?
But then you have the one channel ok.....
Strange one this....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #580873 23rd Jan 2021 5:36pm
wpo750
Just to add, for what it's worth, with either tuner module installed I'm unable to select any other country in the settings. The countries are all listed but pressing on them does nothing.
There's a glitch here's somewhere, possibly software? Worth pulling the battery perhaps?
Post #580879 23rd Jan 2021 6:27pm
wpo750
Just to update this. I've tried three separate tuners now and the same problem persists. Each one manages to give one perfectly tuned channel (Channel 5 with most recent tuner) but with no option to change channel and no suggestions on auto.
If anyone has any expertise to share on this matter I am all ears!
Post #583980 16th Feb 2021 11:03am
coincidently i got this 'one station only' the other day...turned out to be the location i was in..
have you tried re-tuning in a different location? ... - .- -.
Post #583981 16th Feb 2021 11:18am
wpo750
Hey Stan, I have indeed tried different locations but to no avail. Relatively trivial issue this TV thing but really rather annoying that it doesn't work properly. Is there a way to refresh or update the firmware on these systems do you know?
Post #583991 16th Feb 2021 12:02pm
i've not heard of anything like that..normally a tuner module change solves problems.. ... - .- -.
Post #583997 16th Feb 2021 12:38pm
Page 3 of 3 <123
