Home > Technical (L322) > new air compressor |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 922 |
Good for plug n play mate unless you want the height adjusted |
21st Apr 2021 11:36am |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 324 |
Great, thought as much.
21st Apr 2021 9:06pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Good for plug and play if you are swapping like for like Current stable:
22nd Apr 2021 10:48pm |
Put new compressor in as well as relay, still sitting on the bump stops.
27th Apr 2021 4:18am |
27th Apr 2021 4:19am |
27th Apr 2021 4:20am |
Hi guys n gals,
27th Apr 2021 5:29am |
what's the fault? you could have a block or split line? Current stable:
27th Apr 2021 9:28am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1141 |
Before you start pulling any other bits off, run the car stationary, reset steering angle lock to lock and go round the block , not italian style. Then try to set car to all three heights, keep going up and down numerous times
27th Apr 2021 9:58am |
I got physio at 0900 tomorrow so I,ll leave it till after that.
27th Apr 2021 10:21am |
