Home > Maintenance & Mods (L405) > Wiper Blades
Ocean53
United Kingdom 2018 Range Rover Vogue SDV6 Corris Grey
Wiper Blades
Anyone say the best blades to get and from where?
Amazon quotes all kinds of numbers for a 2018 RR 3.0
Post #593046 3rd May 2021 2:52pm
pld118
https://www.fullfatrr.com/forum/topic49162...p;start=15
Post #593050 3rd May 2021 3:56pm
Be careful, they changed design on the L405, not quite sure when - https://www.fullfatrr.com/forum/topic32300.html
Post #593053 3rd May 2021 4:15pm
pld118
The website asks for your reg. number.
https://www.vipacarparts.com/?gclid=EAIaIQ...gLp-fD_BwE
I typed a 2019 reg. number in and it said it didn’t have any stock for that. I typed in a 2018 reg. number (“new design” L405) and it claimed to have stock for that model ie the 2012 onwards, hook wiper arm 🤷
Post #593059 3rd May 2021 5:37pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
went OEM...one place OEM is the best IMO 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #593137 4th May 2021 4:34pm
I think they changed in about 2017?
Post #593164 4th May 2021 8:10pm
Ocean53
I have now managed to change front wipers, ( instructions on how to park in winter position on the control system)
How do you park the rea blade to be able to change it?Cant see anything in handbook.
Post #593500 7th May 2021 4:40pm
Merchy
I may be talking old school here, as my RR is old, operate rear windscreen wiper and just before it teaches mid stroke, switch off engine / car completely without touching windscreen wiper control, so wiper arm is now at 6-O-clock, worth a try.
Post #593502 7th May 2021 5:11pm
Martin2
Put them in the wiper change position and the front ones come up much further than they do in winter park and the rear moves down into a vertical position at the same time.
I can’t remember the exact process, but it is in the manual. Something like turn ignition on, then off, then push down on the wiper stalk. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #593504 7th May 2021 5:21pm
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
Follow this sequence with door open or closed.
1 Switch ignition on then immediately off.
2 Hold down wiper stalk while switching on, wipers front and rear go to park postion. Now change wipers leaving ignition on.
3 Wipers return to normal at ignition off.
Works on 2016 and think it works on other models aswell Thumbs Up
Ian.
Post #593506 7th May 2021 5:29pm
Martin2
That’s what I couldn’t quite remember! Works on my 2019MY MY23 Panamera E-Hybrid
Post #593507 7th May 2021 5:36pm
Ocean53
👍 will give it a try tomorrow
Post #593512 7th May 2021 6:04pm
Plan B for the rear - it stops mid stroke if you open the tailgate. Can be a bit tricky as if you press the button again too soon, it closes again, but too late and it's too high.....
Post #593515 7th May 2021 6:11pm
Ocean53
QWERTY worked a treat, thanks
Post #593597 8th May 2021 12:07pm
qwerty
Post #593613 8th May 2021 3:18pm
