![]() | Home > In Car Electronics (L322) > Ignition won’t turn off, help! |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Disconnecting the battery -ve terminal should do it, it will disable the fuel solenoid and cut off fuel to the engine. |
Deputy Member Since: 23 Nov 2021 Location: Maidenhead Posts: 33 ![]() ![]() ![]() |
Didn’t work. Engine still running. |
Tried pulling fuse 18 to see if it resets ignition switch, no good. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
Is it just idling or revving? |
Idling. |
Is there any smoke from the exhaust? Could be running on engine oil from a leaking turbo. |
You need to block the air inlets somehow to starve it of air. |
No. It’s the ignition barrel. The key won’t turn anti-clockwise to switch the ignition off. It’s stuck somehow. |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
Fuse 25, 31 or 39 |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
or fuel pump relay in rear fuse box? Pulling fuse or relay won't be instant. Need to clear fuel in the lines and filter. John
Pulled 31 and that’s stopped the engine. Phew!!
Replaced the -ve battery terminal to try and start up.
Swap fuse 18 or check it’s clean. Mine had a similar issue and the fuse I used was not making a good contact. Glad fuse 31 worked |
Is yours a key in dash or key down by the handbrake? |
