Home > My Range Rover > Back with another Supercharged! A 5.0 this time!
Page 17 of 19 <123 ... 16 171819>
dhallworth
Been thinking about the Range Rover today...
Our local JLR specialist has quoted me £110 to do a full 4 wheel alignment. Last year I replaced all the bushes and ball joints on the front suspension.
I'm in the process of replacing the bushes on both rear wishbones and both rear hubs at the moment which are the ones that are adjustable for the tracking. The others I can't find any play in with a pry bar.
One thing that I've not yet changed in the time I've had the car are the track rod ends. I can't feel any play in them but I've decided that whilst I'm at it I'm going to replace both of them so that it reduces the risk of it needing to be aligned again if one of them starts to show signs of wear.
I've ordered a pair of them this evening so hopefully they'll arrive soon.
I was looking at wheel centre caps for it too... In 2020 I bought a set of these and they were £27 for 4. Today, they retail at £67 for a set of 4! Shocked 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #718579 25th May 2025 7:49pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Hi David, how did you drive out the bush with one side having a flange on it and getting in the way. I'm thinking of doing mine soon. Do you also think a 10 Ton press will be up to the job?
Cheers, Paul. 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #718586 25th May 2025 10:14pm
dhallworth
The lower wishbones don't have the flange on them, that's only on the upper ones.
They were a sod to remove on my last car as you need to press them from the inside to the outside so you can't use a press on them.
From memory with the last car I burnt the rubber out of them and took them out with a hammer and a chisel.
Refitting the new bushes should be doable on a 10 ton press I'd think, removing the old ones might be a bit more difficult. If it is, heat the wishbone and take them out with a hammer and a chisel being careful not to bruise the bore of the arm.
Post #718587 25th May 2025 10:34pm
PDC
Cheers for that David. At least I now know that there is no way of pressing them out. I will just go carefully when driving them out by hand. 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #718601 26th May 2025 9:08am
dhallworth
Have a look at my post here from 26th March 2022.
https://www.fullfatrr.com/forum/topic57991-315.html
You can see how I attempted it with some threaded rod. I couldn't use a lot of heat as I'd already painted the wishbone with a 2 pack epoxy paint which I didn't have any more of.
I reckon if you put some heat into the arm and tried that method with the threaded rod you'd probably get one of them out. Then blank the hole with a piece of metal and try the other side. Thumbs Up
A little heat into the wishbone makes a huge difference. I just did my lower rears that way after warming the wishbone with oxy/acetylene before they were powder coated.
Post #718602 26th May 2025 9:31am
PDC
Great reading. many thanks! Thumbs Up 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #718606 26th May 2025 10:05am
dhallworth
Managed to get the rear wishbones refitted tonight.
Put some wing protectors face down on the ramp so the wishbones sat on the soft side which allowed me to secure them to the hub and rest them on the ramp so I could refit the airbag into them and position the drop links, etc. before lifting them up and putting the rear bolts into the subframe.
Really pleased with them, they look great.
When you are behind an L322 on the road or when you walk up to it you can see the rear wishbones due to the size and position of them. Peering under mine whilst it's on the ramp tonight shows them looking much, much tidier now.
I changed the last of the bushes tonight, changed both toe control arms and got everything reassembled. It's a good bit of progress in the right direction but I've still got a lot to do.
I'm hoping that tomorrow evening I can get it back on its wheels and off the axle stands as I want to remove the rubber jacking points on the sills so that I can treat round them. Once I've done that I'll be able to paint under them before taking the wheels back off again to paint inside the arches.
Once that's done it getting:
Engine oil and filter change
Front and rear diff oil change
Transfer box oil change
4 new Pirelli Scorpion All Season tyres
Various other little bits and pieces spray painted
I'm not doing the gearbox oil as it's only done around 6k since I fitted the new set of solenoids and did a full service on the box. It had an additional change after the works were finished too so it should be OK. The service history shows it as not being that long since the diffs and transfer box were done, however, I've not done them and I like knowing I've done them all myself.
My plan was then to give everything a good going over with some Lanoguard, however, I'm going to need it outside and off the ramp as the subframe is filthy. It'll need a good going over with the pressure washer before I start that.
I'm going to paint the insides of the arches with Bilt Hamber Epoxy Mastic which is a 2 part epoxy. I want to give that plenty of time to cure before starting to wash the undersides of the car. I might get the alignment done first as I'm not sure the tech at the local specialist will appreciate the car stinking of sheep whilst he does it. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #718701 27th May 2025 11:24pm
dhallworth
Oh yea... I found a pair of genuine Land Rover keyrings that I bought from Duckworths Land Rover years ago so put one of them on the key for this RR tonight.
Smile 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #718702 27th May 2025 11:32pm
dhallworth
Finished cleaning up the steel behind where the jacking points are mounted today. Quite pleased with how they've both turned out.
The mark on the sill that you can see coming out of the 2nd bung is the cavity wax that was put in at the factory.
It's now all had 3 coats of a galvanising primer after the rust bubbles were all burst and wire brushed away. Tomorrow evening I'll hopefully get time to mix the 2 part epoxy mastic and get it all painted. Unfortunately with that stuff, once it's mixed you need to do it all in one go so I wanted everything ready to go with the 1 tin as it's £35 a tin.
Whilst at it today I stripped down the front brakes and cleaned them up as I'd noticed a squealing whilst braking at low speeds. Everything was in great shape with little wear on the discs or the pads but there was some corrosion on the edge of the pads which I cleaned up, then cleaned up the caliper and refitted the pads with some Bilt Hamber Anti-Seize on the edges of the pads.
The pads on the 6 piston calipers are absolutely massive... They're the biggest pad I've ever changed. They make my old XFR pads look small! I thought they looked quite thin but looking at pictures of new ones online these don't look particularly worn at all.
For scale, that's a virtually new 4.5" cutting disc on top of it.
Post #718960 1st Jun 2025 8:02pm
dhallworth
Another job for this afternoon was to change the track rod ends.
The drivers side went off without a hitch and was changed without any problems at all.
The passengers side was a nightmare! It was seized solid. I got the oxy/acetylene out and heated it until it was glowing and then tried to get it undone again. It started to move but very quickly bound up and got stuck again. The spanner then started to slip on the tie rod. I gave it some more heat but it made no difference.
In the end I had to get the angle grinder out and cut a slot down both sides of the track rod end. Once I'd done this I opened both slots up with a cold steel chisel and was finally able to undo the track rod end.
I then wire brushed the thread on the track rod, oiled it up and used the impact gun to run the nut that locks the track rod end up and down it a few times. It cleaned up nicely and the new one went back on nicely. Typical though as it should've been a quick job that turned into a pain.
Thankfully I noticed it before sending it in to the specialist as there's no way they'd have been able to track it like it was. Between that and the bolt that was seized in the rear toe control arm they'd have never been able to align it if I hadn't have given it all a good going over.
Final job for today was to take all of the tyres off all of the wheels as I've had enough of the finish bubbling on them. I'd been meaning to get them sorted at the tail end of last year but figured there wasn't much point before the winter so I let them take the salt before getting them done. The wheels were a bit scabby when I bought it so they're overdue a refurb. I'm desperately hoping they can match the original shadow chrome finish though!
Annoyingly, the finish on them was OK, it was all corrosion under the finish. The backs were a right mess too so I don't think the weights would have actually stuck to them for balancing.
When I bought this car it had the wrong spare wheel underneath the boot floor. I managed to find the right wheel on eBay which has suffered exactly the same as the 4 on my car. So that there's no chance of a colour mismatch if I need it done at a later date, I've decided to get all 5 refurbished this week.
There's 5 wheels, 5 tyres and 5 TPMS valves in the back of the P38 this evening so hopefully I'll be able to get them all in tomorrow morning.
Post #718961 1st Jun 2025 8:07pm
Top jobs as always David, those wheels were on my S\C when I bought it, mine were diamond cut which always leads to corrosion, looks like yours have been painted or powder coated over the top...!!!
Hopefully they will a be well when done properly...
Love the look of the jacking points, great you caught them in time, never seen such clean ones.
Thumbs Up Bow down Thumbs Up Pete
-Click here for Thread-
Post #718995 2nd Jun 2025 9:36am
dhallworth
Thanks Pete.
There’s were 2 finishes on these wheels available from new.
Diamond cut was one of them and shadow chrome was the other one. Having had diamond cut on other cars I’m glad these were shadow chrome as they work well against the silver and it should be a harder finish. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #719001 2nd Jun 2025 10:01am
Gsxr1250dave
Outstanding work !!
Post #719039 2nd Jun 2025 3:58pm
Yes David, you need all the help you can get with the winters you get up there... Shocked Pete
Post #719042 2nd Jun 2025 5:22pm
dhallworth
Thanks Smile
Wheels dropped off this morning. They've photographed the spare which had the best representation of the factory shade of shadow chrome which they reckon they'll be able to match which is great news as I really want to keep it original.
Looking at £5-600 to refurbish the set of 5. They're going to check them for buckles before they start the refurb, if they're buckled they'll straighten them all out but that of course comes with an extra cost of £70 per wheel so we'll see what this ends up costing by the end of the week Laughing
The wife doesn't even know they're not on the car at present so this might take some explaining when they're all immaculate. Laughing
Post #719047 2nd Jun 2025 6:36pm
