![]() | Home > Technical (L322) > blower motor fuse? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
garyRR has just done a full DIY write up on blower motor change if you eventually need it.... |
paulN186 Member Since: 28 Jun 2022 Location: edinburgh Posts: 39 ![]() ![]() |
yeah thanks, I will be following this guide to the letter when i change it! |
Good luck |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
The motor can eventually fail when the brushes wear out or the bearings wear so much, the additional current load fries the motor. 2015 Range Rover Autobiography 4.4 SDV8 |
thanks for the info. so do you know if there is a fuse for it? or it all done through the FSR?
