|  | Home > Technical (L322) > DPF regen on 4.4 TDV8 |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | You need at least a half tank of diesel for the DPF cycle to kick in, and maintain a steady 55 to 70mph on the motorway for the car to even think about doing a regen ( that is providing everything is working as it should be - no air leaks on hoses etc etc )
|  29th Apr 2025 1:33pm |
| JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 310      | Useful - thanks. Exactly what am I looking at on the GAP tool ? presumably under Live Data or whatever it's called ?
|  29th Apr 2025 1:49pm |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285      | It is not the rev level that initiates a regen but the soot level. you get a yellow restricted power warning at c.19 and a red when it gets to around 27 (may need confirmation).
|  30th Apr 2025 11:06am |
| JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 310      | Thanks Dolphin - so effectively, just drive around as normal and if it decides it needs to regen it'll do it if it can and if it can't it'll let me know ?
|  30th Apr 2025 12:25pm |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285      | yup. drive normally so if you start getting RP (restricted power) warnings, then you have an air leak in a pipe or inlet manifold. | ||
|  30th Apr 2025 6:19pm |
| JAD Member Since: 19 Oct 2020 Location: Wirral Posts: 36      | I live on the Wirral Jonny, My amber DPF warning came on in Liverpool city centre the other day. Drove through the Wallasey tunnel and down the M53. By the time I got to Clatterbridge the light had gone out. I normally stick between 60-70mph.
|  4th May 2025 12:59pm |
| D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 575    | You don't need high revs for a DPF regen on these vehicles.  Post CAT EGT's will be 600+ degrees at a steady 60mph in 8th gear.  High revs are not required.
|  4th May 2025 2:11pm |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1564    | High revs are not needed, and i think potentially could discourage the regen process.   You need the engine to be in a situation where:
|  4th May 2025 8:19pm |
| PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 238      | I do quite a bit of green laning in mine low revs in low box and I’ve never had a problem with it doing a regen. Never had an amber or red warning. Did a 3 day coast to coast last week with no issues with DPF at all. Just drive it and enjoy it. | ||
|  5th May 2025 9:52am |
| JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 310      | Plugged in my GAP today and did a run up the motorway for 20 mins or so at a steady 60.
|  15th May 2025 8:52am |
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2724      | If you search there's a huge DPF thread which has incredible detail within it , it has all the answers you need   | ||
|  15th May 2025 9:26am |
| hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 161      | Yes, this is the thread.
|  15th May 2025 9:42am |
| matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 112      | Current version of Gap have it on (dynamic regen) , mine does when i updated and changed the license to me last year on the 2nd hand one i bought . | ||
|  17th May 2025 9:05pm |
| D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 575    | I'm pretty sure that 'Remaining volume' always reads zero when using the GAP IID tool.
|  17th May 2025 9:37pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
 plus you can email Pat @ GAP and ask him to give you access to manually  initiate re-gen function on your IID tool. It used to be a BETA function only , i've no idea if the current versions of the tool have this installed these days as I run a petrol engine .
