Home > Maintenance & Mods (L405) > Replacing batteries - supplier and type
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Evening all
I have a 2016 Autobiography 4.4sdv8 with the 2 battery system. I’m starting to get various spurious low voltage messages and it’s also having an effect on the security tracker electronics.
So, I’m wanting to change both batteries at the same time, does anyone have any advice as to which batteries to install and which supplier to use to purchase the batteries from.
Is it a simple diy job - I have an obd reader that will register the new batteries.
Any suggestions greatly appreciated
Best regards
Mark L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone
and lots of other none LR stuff…..
Post #718437 23rd May 2025 9:38pm
It's all here - https://www.fullfatrr.com/forum/topic65160.html Thumbs Up
Post #718450 24th May 2025 6:12am
nambFFRR
Brilliant….thought someone would be able to help me. Many thanks👍 L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #718451 24th May 2025 6:36am
nambFFRR
All sorted Alistair….ordered both batteries from Tayna so should have them delivered next Tuesday/Wednesday 🤞
One final question, do both batteries need to be registered or just the main one?
Best regards
Post #718453 24th May 2025 7:16am
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
You should register both batteries. _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #718475 24th May 2025 1:13pm
nambFFRR
Ok. Thanks. I have an icarsoft obd reader and it can register batteries apparently L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #718483 24th May 2025 2:21pm
nambFFRR
A few final points....maybe....but wondered if someone can help me.
I have 2 new batteries to fit and realise the batteries need to be registered so what happens and how does the reset tool know which battery has been changed - or in my case, that both batteries are being changed? Is this all done within the BMS?
I've checked out a number of posts now and have picked up I need to let the car de-energise before disconnecting the batteries
Any further advice appreciated before I change the batteries over this weekend....
Best regards
Post #718737 28th May 2025 4:48pm
ReggieMac
Depends on the reset tool that you use. I have a couple but using the iCarSoft LR v3 it knows there are 2 batteries and so you are able to reset each one individually. _______________________________________________
Post #718741 28th May 2025 5:16pm
nambFFRR
Thanks. I have the LRV2.0 but checking with icarsoft as to what my version will do. It’s supposed to cover my year so once I find out I’ll let you know. L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #718742 28th May 2025 6:34pm
nambFFRR
Can you explain the process you went through please as icarsoft have told me the V3.0 doesn’t support the 2 battery setup/registration? I was hoping the V3.0 would be able to do it but I must be missing something somewhere…..any help would be greatly appreciated as I need to get my batteries swapped out soon.
Best regards
Post #719090 3rd Jun 2025 2:36pm
ReggieMac
This should help you
https://www.roverparts.com/Instructions/ic...kZyVms47Vt
Look at page 27 regards BMS
I updated my software on mine a while back and I now get the option of which battery to reset. The manual I refer to above only shows the option of 1 but it should just be an option on the main screen screen once you have verified your VIN.
Post #719091 3rd Jun 2025 2:51pm
nambFFRR
Hi
I updated the V3 I’ve just bought hoping to do both batteries. As you mention the instructions aren’t clear. I’m just wary starting the change over and getting stuck if both batteries arent registered. I guess from what you are saying the unit recognises when either battery is changed and does the registration according to which battery needs registering. Anything else you suggest appreciated.
Best regards
Post #719094 3rd Jun 2025 3:13pm
ReggieMac
I actually have the choice of battery on my screen. I would take a picture but I am at work so cant do that at this time. To be honest there is always an argument as to whether you really need to register a new battery at all because the car will, overtime, work it out itself. I believe the whole reset system is to really prevent the car from overcharging until it works out a new battery has been added.
Personally I always do the reset for peace of mind. If you only 1 option in your BMS then I would just go with that. Thumbs Up _______________________________________________
Post #719096 3rd Jun 2025 3:24pm
nambFFRR
Thanks for the explanation. I’ll give it a whizz…..if you do get a chance to do a screenshot I’d be very grateful 🙏
Best regards
Post #719097 3rd Jun 2025 3:30pm
nambFFRR
Unnecessary quote removed
Hi
Just wondered if you got chance to do the battery registration screenshot for both batteries?
I’d be very grateful if you could send me the screenshot 👍
Best regards
Post #719191 5th Jun 2025 12:37pm
