![]() | Home > Maintenance & Mods (L322) > Getting the driveshaft out of hub? |
| NDT Member Since: 03 Apr 2018 Location: Bedfordshire Posts: 106
Having a nightmare with this and would welcome advice!
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3350
What's the reason you're removing the hub from the car?
| Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 118
A pusher type tool is whats needed. Needs to be suitably large to fit. I got one off ebay but had to grind bits off it to make it fit. Worked fine.
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403
Yes you'll need a pushing tool like the one on eBay... Similar to the JLR tool |
Replacing the CV joint. After failing to do the boot properly last year… |
Thanks - I’ve got an M8 tap somewhere so will do that! |
Thanks all for the help. Will hit it tomorrow after the various tools arrive today. |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1890
| SeldomSeenKid Member Since: 24 Jan 2024 Location: Glasgow Posts: 85
Steve covered this very job on his channel with the hydraulic tool:
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
If you've got a big SDS drill they work wonders in Impact mode |
| GRANGEROVER Member Since: 10 Feb 2022 Location: Bremen Posts: 50
I bought the 10t hydraulic version like the one in your link, with that it's a breeze to get the shaft out 👍 |
The 12T hydraulic pusher worked a treat. Straight out. |
You should also buy the tool to get them back in, that was the bigger issue for me sometimes.
I drill and tapped the end of the shaft to pull it back throug, but actually it went in easily. |
| All times are GMT |
