![]() | Home > Maintenance & Mods (L405) > 2018 SV clunk |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 243 ![]() ![]() ![]() |
Next mission is find the right oil for it and change it the weekend |
Not good at all, probably the wrong oil.
M3bobby Member Since: 28 May 2019 Location: Lincolnshire Posts: 17 ![]() ![]() ![]() |
This is what I bought, the part numbers were from LR topix.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
That’s great to hear, keep us posted |
X1jimmie Member Since: 08 Jan 2019 Location: Hertfordshire Posts: 8 ![]() ![]() ![]() |
Did you get 2L out? Perhaps they didn’t fill it enough. Although you’d hope they know what they’re doing Previously owned: Range Rover L322 2007 TDv8 Vogue SE in Santorini Black |
madasmad Member Since: 22 Mar 2020 Location: Cheshire Posts: 91 ![]() ![]() ![]() |
I have exactly the same problem. I've been told all sorts - fuel sloshing about in the tank, CV joints, bushes, brake disks. However I also believe it is either the diff or transfer box. I will get them both flushed and let's see if that sorts it out. 2019 Autobiography SDV8 Byron blue/black - current
Just pick up the oil for mine, I had to go back as they gave me oil for none E diff, that’s how easy it is so I do possibly have the wrong oil inside.
Done, handy when you have all the tools and pump.
Just done 30 miles, it’s seems fixed. |
Fingers crossed |
Bardley Member Since: 01 Jan 2025 Location: Hertfordshire Posts: 39 ![]() ![]() ![]() |
Rear brake pads releasing from the disc can also produce a thump if its been parked up damp.
Been out for 100 miles and it’s fixed.
RR4ED Member Since: 24 Mar 2025 Location: East Yorkshire Posts: 15 ![]() ![]() ![]() |
How do you know if you need e diff or not? I am going to do this soon and on RRS it was easy with it being DB Dynamic, but not sure with L405! |
Just go to the dealership with the Vin, not reg and get the right oil.
