Home > Maintenance & Mods (L322) > Driver Heated/Cooled Seat
CharlieF322
United Kingdom 2012 Range Rover Westminster TDV8 Baltic Blue
Hi guys,
My heating and cooling function on the driver seat has decided to give up today. The lights still work on the dial but I cannot hear any fans running when on cool and sure cannot feel any heat when on hot.
Usually you hear the relay click when it engages either hot or cold but cannot hear that either.
Has anyone had this before. If so what was the fix? Hopefully just a relay/fuse not the actual element and fan itself.
Thanks
2012 TDV8 Westminster
Post #722037 29th Jul 2025 4:47pm
pcourtney
search the forum for Peltier
lots of good info and advice on here to plough through Smile
see jonnycj post dated 24th May 2025 below
https://www.fullfatrr.com/forum/topic73355.html
https://www.fullfatrr.com/forum/topic44946.html?highlight=peltier
Post #722116 30th Jul 2025 11:16pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
It’s not a difficult job to do, the YouTube tutorials are a good place to start. I couldn’t imagine being without my cooled seats now, especially in this weather.
Be prepared for your ducting to be cracked, so when you do pull the Peltier unit and ducting out of the back of the seat, you’ve got the correct means to repair it.
I used fibreglass, however, the ducting material isn’t particularly conducive to letting anything stick to it, such as glues, fibreglass resin etc although fabric tape or gorilla tape should do the job.
The main reason for cracking is the lip of the metal bar that runs across the back of the seat impacting on the ducting. You can prevent this by bending the lip out with pliers, or if you have super strong grip as i seemed to have on the day, your fingers.
Good luck and keep us posted.
Post #722145 31st Jul 2025 5:58pm
CharlieF322
Thanks chaps.
Did some fault finding with OBD tool. The cooled element is actually still working only on the base but think that’s normal isn’t it? The heated part worked on the base for all of 30 seconds. See the temperature increase on the OBD tool. Then goes into fault mode. Back temperature didn’t seem to move.
Will try and source a part soon and pull the seat apart this weekend.
After this I think the for sale sign will be going on! Getting a little expensive now to do the little mileage I do nowadays.
Post #722146 31st Jul 2025 6:05pm
Limey
United States 2011 Range Rover Supercharged 5.0 SC V8 Fuji White
This is what you need… https://ebay.us/m/T8tGdV
Post #722309 4th Aug 2025 5:37pm
JonnyCJ
Great find Limey
Post #722328 4th Aug 2025 8:55pm
pcourtney
I got mine off Klifex, who are also in Ukraine $26 USD
https://klifex.com/gofra-motora-obduva-sid...-hhk500060
Post #722358 5th Aug 2025 1:37pm
CharlieF322
Well wasn’t expecting this…. It’s all in tact. Must be the heater element that’s gone.
Anyone have a wiring diagram for these so I can buzz it out before shelling out on a replacement?
Post #722417 6th Aug 2025 5:35pm
