![]() | Home > Maintenance & Mods (L405) > Sunroof Drains - Just in time? |
sullivj Member Since: 19 Jun 2025 Location: Gatwick Posts: 43 ![]() ![]() ![]() |
That’s what I’ve purchased to do mine, along with some marine grade sealant.
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 392 ![]() ![]() ![]() |
Marine grade is a good idea 👍
As soon as I get a break in work with decent weather. I’ll post on here when it’s done. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3957 ![]() ![]() ![]() |
Ive been looking at the various threads on this topic and also the tool-station website It seems the pipe inserts are readily available but I did read a thread saying how different metals may interact. I wasn’t actually that bothered as I’ll only have the car for another year or so anyway so if they are corroded after lasting 15 years (and I haven’t looked yet) I’m sure it doesn’t really matter HOWEVER the aforementioned website also has plastic equivalents and I just wondered if that was a better option? Geoff |
Where does the water go if the drain hole is blocked? 🤷♂️ |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 196 ![]() ![]() ![]() |
I will fill up the gutter channel around the pano roof and then either overspill down the outside of the car, or if the sunroof is open, into the car. |
That’s what I thought. So with the sunroof closed and the hole blocked up water shouldn’t get into the car?
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 199 ![]() ![]() ![]() |
I'm guessing that it will collect in the channels and then when you open the sunroof .... whoosh! |
I never use the roof, so in theory I could tape over the holes and forget about it 🤷♂️ |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8128 ![]() ![]() ![]() |
That was my plan B.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1172 ![]() ![]() ![]() |
Deleted! overfinch modified |
Interesting, so no issues with the heavy rain? I’ve bought some waterproof Gorilla tape (excellent stuff) so I’ll use that while I’m preparing the drain and probably cover the drain holes permanently when I’ve finished.. I’ll then monitor the situation carefully. |
No issues - as above, I suspect if I'd have opened the sunroof the following day, I'd have got wet. Probably true if I'd opened a side window and gone around a corner too. |
Thanks that’s good to know. |
