Home > Maintenance & Mods (L405) > Sunroof Drains - Just in time?
Page 3 of 5 <12345>
sullivj
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
I like the sleeve solution, I'm just concerned about what I can't see...
If the tube is badly rusted, it's not unthinkable that it could still fall away from the insert and leak water into the car.
Post #723084 19th Aug 2025 11:48am
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
The idea of the sleeve is that it extends inside beyond the end of the original drain hole so that if the original drain did become disconnected then the insert will hold everything in place, at least hopefully long enough until you detect it on your next regular inspection, and minimise any water ingress. _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #723086 19th Aug 2025 12:07pm
ReggieMac
adara wrote:
Thank you so much ReggieMac for sharing the sleeve solution that simplifies the procedure immensely!
I wish I could take credit for it but that belongs this chap at 'Critical Reviews' here
https://www.youtube.com/watch?v=rQpp2mm-lH0 _______________________________________________
Post #723087 19th Aug 2025 12:10pm
You can also pull the headlining away, just in front of the rear grab handle and shine a torch up to see where the rubber tube attaches.
I gave mine a wiggle - one seemed solid, the other came off Big Cry So I've cleared out all the rusty remains of the original tube that was inside it and now need to reconnect it to the insert. However, I need another bit of pipe as the insert is all that remains and is narrower than the original drain. I'm guessing a short length of the Hep20 pipe will work best Confused
I also had one that was blocked at the exit as well - that's located in front of the secondary battery. Easy to clear with a bit of strimmer cable.
Almost there.......
Post #723118 20th Aug 2025 8:07am
linus
United Kingdom 2016 Range Rover Vogue SE TDV6 Santorini Black
Hi, I was about to check the on my L405.
However, I have a fixed panoramic roof, that doesn't open. Does it have the same drains and if so how do I get access to them, if I can't open the roof?
Thanks.
Post #723797 2nd Sep 2025 1:22am
linus
OK looking at the Critical Reviews YouTube video it looks like I just have to remove the trims and I will be able to see the drains. The sunroof doesn't need to open.
I will be looking at this over the weekend.
Post #723798 2nd Sep 2025 1:39am
I think that the drains are only present with the opening roof. There's no reason for them to be there with a fully fixed roof, only for the opening mechanism.
I don't actually know though, so would be interesting to find out for sure Thumbs Up
Post #723799 2nd Sep 2025 7:18am
linus
Thanks, I am guessing but I assumed the panoramic roofs are interchangeable in terms of size and just fitted into the roof. The body is probably the same though which makes me think it should have them.
Unless someone knows definitively I will have to have a look. I will put a message on here once I have had a chance to have a look.
A couple of questions though, does the epoxy need to be down the entire length of the sleeve or just the first 5 millimetres or so?
If there is some rust there I assume I need to treat the rust first. I assume a rust converter would be sufficient?
Post #723803 2nd Sep 2025 9:48am
Gremlin500
Thanks.
Relax, the fixed panoramic roof is bonded in, much like your windscreen, and there are no roof drains.
Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #723806 2nd Sep 2025 10:16am
linus
Phew...I can strike that from the list of things to worry about.
Thanks, Gremlin and Alister, for replying.
Post #723807 2nd Sep 2025 10:35am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Does the L322 suffer from the same issue ?
I've not heard of it being talked about quite so much, I'm thinking I need to flush mine out as a just in case.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #723817 2nd Sep 2025 3:24pm
linus
It would seem like it, according to this by powerfulukltd.
Sunroof water leaks & fault finding on Range Rover L322
https://www.youtube.com/watch?v=fwKBFSnmrQ0
Post #723819 2nd Sep 2025 3:58pm
AndyRoo
OK, thanks, new tool it is then Whistle
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #723822 2nd Sep 2025 5:08pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Ok just checked mine and lucky I did, one side looks good the other not so…..
Although it appears to be completely blocked so where will the water go? I’ve not had any issues that I’m aware of. Should I just leave it?
Post #725423 30th Sep 2025 3:41pm
sullivj
I wouldn't just leave it. It looks like there is quite a bit of corrosion in there, meaning it's only a matter of time before the pipe becomes detatched and then ALL of the water will flow down your A Pillar and into the floor.
At the moment, the water is probably running through the intended route - albeit slowly.
Post #725424 30th Sep 2025 3:53pm
Page 3 of 5 <12345>
