Home > Maintenance & Mods (L405) > Sunroof Drains - Just in time?
Page 2 of 5 <12345>
Kot
Screwfix sell them £4.99 for pack of 10, and they also sell No Nonsense 2-Part Epoxy Adhesive Tubes Opaque 30ml £4.49
All stocked up, just waiting for recent hand surgery to heal and stitches out Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #722392 6th Aug 2025 9:55am
Monty+4
United Kingdom 2019 Range Rover Autobiography TDV6 Loire Blue
I have obtained some brass inserts to the same design and size as those mentioned.
As a precaution I checked compatibility of the different metals, it appears that brass in most applications is fine with steel, it is not with carbon or stainless steel in a wet environment, I also noted that mild steel and stainless steel are not compatible in a wet environment, the differential is likely to increase the speed of corrosion in the mild steel component.
I guess the epoxy will possibly insulate the two components from each other
Does anyone know what metal is used in the sunroof drains?
Post #722408 6th Aug 2025 2:58pm
Monty+4
Post #722409 6th Aug 2025 2:58pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
I'm not entirely sure about using brass and steel together—refer to the table below for more details. Brass sleeves are readily available in various sizes, but from what I've read, they're not recommended. That’s why I opted for the Wavin inserts instead.
Post #722411 6th Aug 2025 3:51pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Have just completed the same modification to a friends 2018 405, his were a little worse than mine but still pretty solid overall. Treatment with rust converter, numerous coats, surrounded inserts with high pressure flexible sealant to avoid any change of cracking and thoroughly tested today after allowing 24 hours to cure. I am getting the hang of doing these sunroof drains but I hope I never have to do a 'proper' drill out and refit job! Bow down Thumbs Up _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #722628 10th Aug 2025 1:01pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I've just checked this on my 2017 model - one side was fine and the other was clearly in the need of some attention. It is very easy to remove the trim to gain access to the drain holes - open the sunroof and then gently but firmly pull up and outwards on the trim. I started at the front as it was easier to get a hand hold. Putting the trim back is also straight forward. Line it up and then a tap with the side of the palm gets it back in place.
Can you tell which side needed attention? The clue was there was a pool of water that hadn't drained away properly. Cleaning out the partly blocked pipe helped.
When testing for drainage, pour some water into the channel and it should drain quickly out from behind the rear wheel.
I've treated it and will monitor going forward.
 Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #722648 10th Aug 2025 5:54pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I just checked mine on my 2014 SC. I noticed that when I drove off with my window open, water drops were coming in from above.
I took off the plastic strip along the side of the sunroof and the drain was crusted over with muck. I cleaned it all out and luckily no visible corrosion. Same on both sides.
Did not take long and worth a regular check. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #722741 12th Aug 2025 4:52pm
Also worth pouring a cup of water down & confirming where it comes out.
Post #722744 12th Aug 2025 5:30pm
RRBlue
Yes indeed, many 'cups of water invested', as well as compressed air until a healthy trickle was seen behind the rear wheel. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #722747 12th Aug 2025 5:52pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I Love this forum for the information and help provided have been here since 2009. Have to say, I've got a 2017 (67) SVAutobiography, and I'm really tempted to just sell it. it's not as classy as my L322, and Jaguar (Tata) have given up. They seem to be garbage build quality. It's like a 50% Range Rover, I'm sure they had to enshittify the proper Range to pretend a Sport (Discovery in Drag) or an Evoque (Freelander for the overpaid Metropolitan "Elite" ) are "Range Rovers" I'm just depressed and stressed waiting what what is going to Censored the bed prematurely because accountants with the taste of someone who likes Dubai builds these damn things now. Am I way off? Am I in any way wrong, or should I jump ship? Formerly happymadison1978
Post #722924 15th Aug 2025 11:03pm
Gremlin500
Shocked
I would have thought it’s not a good idea to leave any corrosion in place?
Surely the only sensible remedy is to totally remove any rust to bare metal, and go from there?
I’m a bit shocked at what people think is acceptable, to be honest.
Any corrosion left in situ will only later come back to bite you in the proverbial, surely? V6 Vogue - “Less is More” - less to go wrong!
Post #722925 16th Aug 2025 1:23am
I guess it depends on the cause of the corrosion & the effort to 'totally remove to bare metal'.
Some 80/20 rule has to come into play IMHO. If the corrosion was caused by a historic blockage that isn't likely to happen again...... Is this likely to be what causes my car to be finally written off ?
It's somewhat similar to - more men die with prostate cancer than because of it. It's not automatically worth treating if you're old enough & have other ailments.
I guess you could remove the headlining and spend a day or more on it, but for most, some rust eater & an insert epoxied into place is likely to be sufficient to see the vehicle to its end of life from a more serious cause IMHO
Post #722930 16th Aug 2025 10:56am
adara
The sleeves arrived last week, so I started by preparing the drains.
First, I applied some Pattex rust remover, followed by 2 coats of black anti-rust paint.
Once that dried, I used some of the Bostik compound on the sleeves and inserted them into the holes. I believe this should solve the problem for a while.
If anyone in Europe wants to try this fix and can't find the sleeves locally, I'd be happy to send you a pair.
Post #723074 19th Aug 2025 10:02am
ReggieMac
Nice job. For something that could be such a catastrophic issue for the car it is a nice quick and easy solution that should at worst, if there was already quite a bit of corrosion but the drains are still intact, buy a few years and at best should, in my opinion, last the lifetime of the vehicle. Just need to remember to add the checking of the drains to your regular annual maintenance. Thumbs Up _______________________________________________
Post #723081 19th Aug 2025 11:13am
adara
Thank you so much ReggieMac for sharing the sleeve solution that simplifies the procedure immensely!
Post #723083 19th Aug 2025 11:40am
Page 2 of 5 <12345>
